Engel 39lt fridge
Submitted: Tuesday, Feb 02, 2016 at 15:02
Stephen F2
All I want to know what is best set up to run Engel fridge 39lt for max of 3 days .I have read elsewhere people running them on just 1 battery for upto 4 days without charging.I have 1 Solar Panel 100watts Mono Crystalline and have dual battery setup with Redarc isolater.Both current batteries are just lead acid starter batteries ..Sorry asking again similar question again..
.I have contacted Battery companies and no one gives a diffinitive answer to running a fridge .cheers
Reply By: Glenn C5 - Tuesday, Feb 02, 2016 at 15:17
Stephen. The set up you have will run that fridge no probs. Hook up the solar if you are stopping for any length of time. Cheers
595819
Reply By: Spanner69 - Tuesday, Feb 02, 2016 at 15:26
Hi Stephen,
You may wish to read similar previous posts on this issue, but will agree with the only comment, you should be fine with the set up you have.
I have similar set up and have no issues and I run two fridges, one used for a freezer, noting use the panel when stopping at all times.
Paul
595821
Follow Up By: Stephen F2 - Tuesday, Feb 02, 2016 at 15:31
Thanks Paul so my 100watt panel enough to keep aux battery topped up when stopped, off course depending on sunshine hrs ..Just seems have to be Rocket Scientist reading many other Forums and articles on this subject ha ha ha
864542
Follow Up By: Gronk - Tuesday, Feb 02, 2016 at 20:28
The 100W may not be enough to keep it topped up, but over 3 days, it will charge it enough to run the fridge OK.
Get that solar out, and if it's cloudy for 2 days, worry about it then !!
864568
Reply By: Spanner69 - Tuesday, Feb 02, 2016 at 15:48
I tried this with my truck, one battery and the solar (120W) and had no issues for a couple of days, noting sunlight is required. Now have changed to two batteries/redarc DC/DC charger, now running at 14 +volts all day.
The responses you are getting are due to many factors, how big are the batteries/what sort lead/acid etc, how old is the alternator, this information can be achieved by going to a auto electrician, a good one also. One whom has done this work previously. Is your best bet
They will assist you to understand what power comes out and what you need to run the fridges etc.. or check out the redarc webpage, if you haven't already and what gear you need.
Good advice is gold when having this gear to run your fridges, dont skimp on good advice or you will be one unhappy chappy
Paul
595822
Reply By: Member -Dodger - Tuesday, Feb 02, 2016 at 16:09
Your system should work ok with good sunlight.
Hint......... even when you first stop set the solar up so that it is producing power until sundown .
Remember that ambient temps and where you
park the vehicle will have an effect on the fridge and solar.
595824
Reply By: Member - mechpete - Tuesday, Feb 02, 2016 at 16:19
hi Stephen ,
when we were camped along the finke race track in 2014 we sat for 5 nights ,ran the 39lt engel
an lights at night never started the 4wd , my 64w solar panel was connected to the aux battery
which ran the fridge an lights , early avo we would reposition the panel to get the late avo sun
an the fridge an lights worked perfectly
cheers mechpete
595826
Follow Up By: Stephen F2 - Tuesday, Feb 02, 2016 at 16:24
Sounds good what battery were u running.I worked at Finke Aboriginal community back in 2008. Loved it but the NGO I worked for very...
well I should not say .But I loved that area and went out on some wild tracks with the local boys..cheers
864546
Reply By: pop2jocem - Tuesday, Feb 02, 2016 at 16:24
Stephen,
I have a 39l Engel. My setup is an 80 watt solar panel which I move around to follow the sun. I have a 100 AH DC battery and a Powertech controller. When we did a bit more
bush camping for extended periods I had 2 of the 100 AH batteries. Could have done with probably 120 watt or thereabouts of solar panel.
Anyway, with the single battery and the 80 watt panel we are good for about 2 days without any other power input i.e. plugging into a generator or starting the vehicle. Still good for a bit longer but the battery voltage would get a bit too low for my liking or good battery life.
The other factors that probably caused some issues is that my Engel is about 20 years old and I do like my beer cold so it was working pretty hard.
Apparently the newer fridges are more power economical.
Pop
595829
Reply By: 2517. - Tuesday, Feb 02, 2016 at 20:05
Hot weather is the problem this system works
well in normal condition ,we were at
Tamworth for the festival my mate had 100w panel it could not kept up we were there for 2 weeks very hot ,but if you run the car and kept it out of the sun you are a chance.
595839
Reply By: Member Andys Adventures - Tuesday, Feb 02, 2016 at 20:09
Hi Stephen,
I have 2 40lt engels one as a fridge and one as a freezer I run 2/ 80ah deep cycle batteries and have 2/ 80 Watt solar panels. I can run them all the time without going near a power point. So if you half it 80watts and 80ah will be enough... I also run a tv and lights with it and am in the Top End all of the wet so it is hot as
well .....
Cheers Andy
595840
Reply By: Top End Az - Tuesday, Feb 02, 2016 at 21:14
My 39 Engel is good for about 2.5-3 days running off a Century Marine Pro, before the battery indicator reports 50% discharge. This is without solar.
Mind you we do drive around and explore a bit when camped up for a few days so it does get a partial charge in the meantime. We got 3.5 years out of this battery so not bad for a couple of hundred bucks.
When we drive we turn the temp of the fridge right down, then put it back up a bit higher when
camping. If you have solar you will be fine. If the sun isn't out you can charge the old fashioned way by letting the car idle for a while as I have seen many people do.
595843
