Low grade fuel in Top End
Submitted: Wednesday, May 26, 2004 at 08:15
ThreadID: 13166 Views:2018 Replies:2 FollowUps:4
Any of you interstate diesel owners travelling to the Top End in coming months could very well experience diesel knock due to our low grade fuel. Our fuel comes in from Indonesia and has never been the same quality as what is available in other parts of the country. Of late, diesel seems to be of a lower cetane rating which will cause knocking and I have experienced this in my 1HZ over the past few months.
Diesel 1
Reply By: daddy - Wednesday, May 26, 2004 at 09:45
I tend to use an additive such as Diesel Power and it seems to do the trick.
Chris
AnswerID: 60210
Follow Up By: Rick Blaine - Wednesday, May 26, 2004 at 09:57
If your talking about Diesel power plus.. the blue stuff.. I use it in the winter in Canberra seems to make starting easier... but I notice that the active ingredient is ethanol.... A mate puts about 25 ml/100ltrs of metho in his fuel and he says that that does the job...But ethanol wouln't increase the cetane rating just make the diesel a little more volatile...
FollowupID: 321779
Follow Up By: daddy - Wednesday, May 26, 2004 at 17:59
Hey Rick, this one's called Diesel Power, it's yellow in colour and states it contains 880g/L 2 Butoxyethanol. So I guess it's probably the same as the product you mentioned.
Actually, when the good wife noticed that the name began with Butox, she automatically equated it with Botox and wanted to inject it into her forehead to reduce her wrinkles. I told her I'd have to start buying it in 44 gallon drums to make any difference!!
FollowupID: 321826
Follow Up By: Diesel 1 - Thursday, May 27, 2004 at 07:31
I've tried a couple of different additives to try and overcome the problem, but not Diesel Power. As you say, the active ingredient is ethanol which would definitely contribute to easier starting in lower temps, but it would not boost the cetane rating.
Ideally, the cetane rating should be 40 or above to eliminate diesel knock - I don't know what the rating is for this low grade fuel in Darwin.
BP boast a nationwide rating of 45, but it would seem that their standard might not apply to the Top End. The worst fuel appears to be Shell which might explain why they offer 4 cents/litre discount with Coles shopping dockets.
Diesel 1
FollowupID: 321946
Reply By: Member - Mike H (VIC) - Wednesday, May 26, 2004 at 17:00
Hi Diesel 1,
do you ( or anyone else ) know if the Santos Refinery at Alice is finished with their upgrade and producing again?
Or are they still shipping in the diesel?
Thanks,
Mike
AnswerID: 60258
Follow Up By: Diesel 1 - Thursday, May 27, 2004 at 07:33
G'day Mike,
I couldn't comment on the Alice refinery - perhaps Slammin can answer that one - it's his neck of the woods.
Diesel 1
FollowupID: 321947
