viscount 1982
Submitted: Monday, Feb 22, 2016 at 18:41
kman1
Hi Guys,I am trying to replace the front perspex corner windows of my 1982 viscount poptop.it appeared easy but after removing multiple screws and sealant I can't move anything.Please help.
kman
Reply By: Jim-Bob1 - Tuesday, Feb 23, 2016 at 22:01
G'Day kman1,
I have a 73 Viscount and I took out the 4 corner windows and squared the corners and replaced the centre windows with smaller ones, mainly to stiffen the van and keep out the dust.
So if you have removed the 18 or 20 screws that hold the window, the only thing holding it in is the sealant they used when assembling the van.
From the inside of the van, use a piece of 3x2 wood and hammer to knock the frame out by working your way around the frame. You may also have to use a pinch bar, or a big screw driver, to lever out the window at the same time as
Be careful not to distort the window frame.
Hope this helps.
Regards Jim-Bob
596568
Follow Up By: kman1 - Wednesday, Feb 24, 2016 at 19:44
Thanks Jim-bob,Your excellent advice enabled me to successfully remove the windows.
kman
865504
