Q for the battery/electrical gurus
Submitted: Wednesday, Feb 24, 2016 at 16:45
ThreadID: 131680 Views:2709 Replies:3 FollowUps:2
Could one of you learned posters tell me what the highlighted figures refer to in this battery charging table. thanks
Reply By: Member - Racey - Wednesday, Feb 24, 2016 at 17:01
The "C" refers to the battery capacity. E.G. 100 amp/hr battery charging current = 100 x 0.3C = 30 amps
AnswerID: 596603
Reply By: Battery Value - Wednesday, Feb 24, 2016 at 21:04
As has been said, the max allowable bulk charging rate is 0.3C (e.g. 30A for a 100Ah battery).
Once the absorption level of 14.7V has been reached the max time after which the charger should switch back to float is 2 hours.
The rest of it doesn't make sense because these lower float voltages can be applied without time limit.
Where did you find this piece of (mis)information?
AnswerID: 596619
Follow Up By: Member - wicket - Wednesday, Feb 24, 2016 at 22:50
This is not (mis) information but rather the charging regime for Lead Crystal batteries, if you aren't conversant with them , they are somewhat new on the scene, then have a read about them here, lots to like about them
http://www.alphaenergy.com.au/Lead-Crystal-Batteries
FollowupID: 865517
Reply By: cruza25 - Thursday, Feb 25, 2016 at 12:37
These could be an interesting new alternative for 2nd battery and camper trailers
A 55a optima yellow cost around $340
A 55a lead crystal around $440
The spec says they can fully discharge without loss of capacity
We need a volunteer to field test them in real life touring use
http://au.rs-online.com/web/p/lead-acid-rechargeable-batteries/8262758/
Spec sheet
AnswerID: 596643
Follow Up By: HKB Electronics - Thursday, Feb 25, 2016 at 13:46
Are you talking about the Optima or lead crystal?
The specs for the lead crystal show:
Greater Cyclic Life - 6000 cycles to 20%, over 1600 to 80% DOD
that indicates they suffer from over discharge like any other battery.
It has been circulated that Optima's can be discharged to zero without
harm but the company won't provide a life versus DOD stating that it is
commercially senstive information!
The last I read on Optimas was:
1200 cycles to 0% SoC ( 10.5v ) and 2,000 to 20% SoC ( 11.58v )
so Optimas also suffer the same as any other battery if severly discharged
similar to the above.
FollowupID: 865548
