Injector cleaner.
Submitted: Wednesday, Feb 24, 2016 at 21:09
ThreadID: 131683 Views:3664 Replies:9 FollowUps:17
Once an old mechanic told me to put some in as it helps.Is this fact or fiction ???
Reply By: Notso - Wednesday, Feb 24, 2016 at 22:56
Yeah, I remember a while back I was adding Castrol Fuel Doctor to my diesel tank and the bloke next to me asked if it did any good. I said blowed if I know mate, but it makes ME feel good!
AnswerID: 596626
Follow Up By: Stephen F2 - Wednesday, Feb 24, 2016 at 22:58
Placebo effect...they injected athletes with Saline solution and they all ran faster Hope my Hilux thinks thatit works too...
FollowupID: 865519
Follow Up By: Notso - Wednesday, Feb 24, 2016 at 23:01
Yeah, Just after this incident I went to the local diesel service and asked one of their mechanics. His response was definitely use it especially in diesels and when you are travelling using lots of different and possibly less reliable suppliers.
FollowupID: 865520
Reply By: mountainman - Wednesday, Feb 24, 2016 at 23:29
Mine puts some in my fuel tank
2h diesel
nit sure if its a profit based method of action
but ive used the guy more than 10years
AnswerID: 596628
Reply By: Roachie Silverado - Thursday, Feb 25, 2016 at 05:43
I use Chemtech Diesel stuff every fill-up in my Silverado's Duramax.
The way I see it, I paid $105- for 5 litres of the stuff and use 100ml per 100 litres everytime I fill up. I use around 16 litres (of diesel) per 100 kilometers, so 100 litres of diesel (and 100ml of Chemtech) will get me around 625 kilometers.
Therefore, my 5 litre drum of Chemtech should last me for 31,000 kilometers......and cost me about 33 cents per 100 kilometers.
Compare that to the potential cost of 8 new injectors for this truck and all of a sudden the initial outlay of $105- sounds pretty cheap to me!!
Roachie
AnswerID: 596630
Follow Up By: Stephen F2 - Thursday, Feb 25, 2016 at 08:40
Is Chemtech from WA .And just wondering do the manufacturers of Diesel vehicles advise using injector cleaners thanks
FollowupID: 865531
Follow Up By: Idler Chris - Thursday, Feb 25, 2016 at 09:34
People take vitamins and supplements and who knows if the do much good. We take out insurance for events that we do not expect to happen. We put second fuel filters on just in case we get bad fuel. We put winches on just in case we get stuck and there is no one else around and there are plenty of trees Roachie's use of Chemtec is in the same vain and very hard to fault his logic.
FollowupID: 865532
Follow Up By: Stephen F2 - Thursday, Feb 25, 2016 at 10:37
Hiya Idler Chris but being a mechanical device surely there's some evidence it works bit different to ingesting vitamins ..
FollowupID: 865535
Follow Up By: Member - Tony H (touring oz) - Thursday, Feb 25, 2016 at 10:38
Hi Roachie,
Would really like to contact you, as your not a member, what is your preference if your happy for me to make contact.
I want to quiz you about your Chev experiences
Thanking you
Tony H
FollowupID: 865536
Follow Up By: Roachie Silverado - Thursday, Feb 25, 2016 at 15:40
G'day Tony,
Feel free to contact me.....
Phone 0414 890 148 or email... broa7042ATbigpondDOTnetDOTau
Bill
FollowupID: 865553
Follow Up By: Member - johntoyo - Thursday, Feb 25, 2016 at 17:05
Roachie, if I am not wrong I think you will find that your Silverado additive had nothing to do with cleaning injectors and more to do with meeting emission requirements.
John.
FollowupID: 865558
Follow Up By: Roachie Silverado - Thursday, Feb 25, 2016 at 17:42
Sorry John....can't agree with you there. I think perhaps you are getting diesel additive with "Adblue"?
Roachie
FollowupID: 865561
Follow Up By: Member - Phil G (SA) - Thursday, Feb 25, 2016 at 20:41
I do the same as Roachie - use Chemtech every tank. Been doing this for over 25 years.
On my old 47, 61 and 79 series diesels it would reduce smoke out the exhaust and improve fuel consumption.
On the 200series and our Tiguan, it is used because it has an algaecide and because it precipitates emulsified water. And those vehicle run sweet when I use it.
It only adds about 3c per litre to the cost. I've not had an injector issue on any vehicle, and never had water or algae in my fuel and I'm the one who has done every fuel filter replacement in that time.
I first started using it when recommended by a truckie.
FollowupID: 865567
Follow Up By: Stephen F2 - Thursday, Feb 25, 2016 at 20:48
Interesting on label of Chemtech does it list its ingredients..I just bought another brand all it says liquid hydrocarbons 840ml/l
FollowupID: 865568
Follow Up By: Roachie Silverado - Friday, Feb 26, 2016 at 05:59
I've also fitted a FASS 150 lift pump/water trap/filter close to my tank on the Silverado.
Looking at the youtube blurb, I was convinced about the level of injector damage that can be caused by air in the fuel as well as the idea that it takes away some of the effort required by the CP4 injector pump to suck the fuel 3+ meters from the tank to the engine.
Maybe it's snake oil, but I've fitted it and have no regrets.
https://www.youtube.com/watch?v=x4LCbGsujdU
Roachie
FollowupID: 865580
Reply By: swampy - Thursday, Feb 25, 2016 at 15:54
hi
commercial injector cleaner works 100% used during cleaning, testing etc etc
Domestic cleaner 50/50
Domestic cleaners donot clean 100% nor will they stop water or algae growth, in a tank 100% either.This includes carbon build up also .
Better than nothing but not bullet proof or 100 honest .
If your engine develops an issue the cleaner will have zero benefit .
Injectors on petrols can still block up if a misfire occurs . Domestic cleaner will not fix this .
The cleaner would typically have greatest benefit to emission readings .
swamp
AnswerID: 596650
Follow Up By: Roachie Silverado - Thursday, Feb 25, 2016 at 17:44
Swampy,
Please clarify what you mean by "Commercial" and "Domestic" cleaners...EG, what brands are you referring to please?
Roachie
FollowupID: 865562
Follow Up By: swampy - Thursday, Feb 25, 2016 at 18:40
HI
Domestic cleaner is what u find at supercheap etc . Commercial cleaners are used when cleaning injectors off car mainly .Connect injectors to injector machine which would buz the injector at different rates when it is bathing in the fluid [ultrasonic cleaner ],there is an on car machine also [carbon clean ]. Mainly for petrol vehicles .Both systems have there pros and cons .
We used to sub out the diesel injector/pump stuff .The later DID injectors would also be using an injector cleaner . Apparently treated the same way petrol injectors are ,although I cannot confirm this. They are now reconditioning DID injectors.
swamp
FollowupID: 865563
Reply By: MUZBRY- Life member(Vic) - Thursday, Feb 25, 2016 at 16:12
Gday
Im going to inject mine with a "saline mix and a hand full of vitamin pills" that'l fix it
AnswerID: 596651
Follow Up By: Stephen F2 - Thursday, Feb 25, 2016 at 17:11
Good sense of humour.Looks like most 4wheel drives these days are on steroids! Apparently tye LC.is getting bigger on the outside but smaller inside.Even from 60series to 80series I noticed less space inside...
FollowupID: 865559
Reply By: Sigmund - Friday, Feb 26, 2016 at 10:11
Premium fuels have cleaner in them. That may do something.
I used to put petrol injector additive in the sedan. On the other hand, I have mates with over 100,000 kms on their sportsbikes, which have highly tuned engines, that never saw a drop without ill effect.
AnswerID: 596683
Reply By: Member - Cuppa - Friday, Feb 26, 2016 at 10:40
I'd never used the stuff but when Supercheap had their own brand injector cleaner on sale for $2 instead of the usual $12 or $13 I decided to give it a try in my 4.2 Nissan diesel. I put it into both tanks, from which I have been getting a range of around 1000kms. With the injector cleaner in I could feel absolutely no difference to performance, but by the time I needed to refill I had covered 1140 kms of the same type of driving I usually do.
I put the significant improvement in the fuel consumption down to the fact that I had removed the rooftop tent! :)
AnswerID: 596687
Follow Up By: Member - ACD 1 - Friday, Feb 26, 2016 at 11:41
Oh! Cuppa
You have just caused me great embarresment
My workmates have just come to my aid after falling of my chair... They thought I'd hurt myself, but I new from that warm, damp felling in my pants that I had just bleep myself laughing.
That should be in the Friday Funnies thread. Well done!
Anthony
FollowupID: 865595
Follow Up By: Stephen F2 - Friday, Feb 26, 2016 at 12:39
Cuppa you must have felt good saving 10 bucks or so...
FollowupID: 865598
Reply By: Alloy c/t - Friday, Feb 26, 2016 at 11:02
Chemtec also make a great engine oil gallery cleaner , when we had the 80 series turbo diesel by the book oil and filter change was stated as 9lt , and the new oil would be black after 100 or so km . Used as directed the additive to the oil prior to the next oil change ,11lt of the blackest thick gunk came out of the drain hole , and oil stayed clean and bright from 1 change 5k to the next .
AnswerID: 596689
Reply By: 9900Eagle - Friday, Feb 26, 2016 at 13:37
Here is a bit of info for those interested. There is on going change by the fuel companies to keep up with the latest Euro specs and the advancement in diesel engines.
Caltex new fuel testing
AnswerID: 596695
