Exhaust Systems and Steinbauer Performance Chip
Submitted: Wednesday, Apr 13, 2016 at 16:59
ThreadID: 132117 Views:7186 Replies:8 FollowUps:7
After 2 weeks research, including through this forum, and sometimes painful dealings with new car sales people, we have decided to keep our Patrol and maybe tweak it to gain better torque and performance. I am looking to put on a Beaudesert Exhaust and a Steinbauer Performance Chip. What are your opinions please?
Reply By: carl h2 - Wednesday, Apr 13, 2016 at 17:39
hi Greg save yourself some money and get your Exhaust from the 4wd super centre.
AnswerID: 598604
Follow Up By: Malcom M - Thursday, Apr 14, 2016 at 07:04
Not much detail there.
Do you have any reasons other than price for this?
Any provable performance gains compared to other makes?
FollowupID: 867806
Follow Up By: carl h2 - Thursday, Apr 14, 2016 at 18:02
hi greg have the 3" system on my hilux its made by berkley Exhaust comes with three year warranty has the tap holes for your gauges it was easy to fit all for $650 delivered yo your door very happy.
FollowupID: 867835
Reply By: Member - peterdre - Wednesday, Apr 13, 2016 at 19:39
Hi Greg,
Get the biggest exhaust possible, no DPF, hi flow cat. Forget about the chip.
Pedro
AnswerID: 598610
Reply By: Isuzumu - Wednesday, Apr 13, 2016 at 19:53
Hi Greg, a little more info on the Patrol please, year, motor nanda mileage please. As there is a lot of problems with some older models.
AnswerID: 598611
Follow Up By: Greg_513 - Thursday, Apr 14, 2016 at 08:16
Bruce, It's a 2008 3L Diesel Auto. 146000Km I tow a 21'6'' Van weighs 2100 empty.
FollowupID: 867809
Reply By: Mick O - Wednesday, Apr 13, 2016 at 22:29
Include an EGT gauge with that fit. Remember the Steinbaur is a simple plug and play model that simply adjusts fuel rail pressure or fuel pulse so it provides more power by dumping more fuel into the motor. The resultant exhaust gases have to go somewhere so the larger exhaust system is a must. One of the byproducts of more fuel combustion is heat so you really need to know what's happening inside the motor temperature wise lest you slag out the top of the No.4 piston (a particular problem in the GU 3L models 2001-2004).
I did a write up on my performance mods on the Tojo here.
Ute build
AnswerID: 598621
Follow Up By: Greg_513 - Thursday, Apr 14, 2016 at 08:18
Thank you Mick.
FollowupID: 867811
Follow Up By: TerraFirma - Friday, Apr 15, 2016 at 12:38
The SB Chip does not dump more fuel into the motor. The SB chip adjusts fuel injection timing to create more power. Dumping more fuel into the motor is a technique used by other chips and is not desirable.
FollowupID: 867863
Follow Up By: Greg_513 - Friday, Apr 15, 2016 at 15:03
Thank you TerraFirma. That was my understanding with this chip.
FollowupID: 867871
Reply By: Bob Y. - Qld - Thursday, Apr 14, 2016 at 08:31
Fitted a Beaudesert 3" exhaust to an 80 series wagon we used to have, Greg. Had a problem when it was rubbing on a long range tank and they rectified it, no charge. Highly recommend them.
Fitted a Redback system to our '02 Landcruiser ute(now sold) because I didn't want to root around with the dump pipe that Beaudesert now supply. Was a good system, very easy to fit. Spare parts are also available.
Can't comment on the chip, but feel there would be better options for that 3L engine.
AnswerID: 598623
Reply By: noggins - Thursday, Apr 14, 2016 at 19:37
First thing to do is to block the EGR
That way piston 4 has a better chance of survival in the future
zz
AnswerID: 598648
Reply By: Paul E6 - Thursday, Apr 14, 2016 at 22:57
I've got a Steinbauer on my rodeo.
It was worth doing, but a big exhaust would top it off nicely.
AnswerID: 598660
Reply By: Boof, Bairnsdale. - Friday, Apr 15, 2016 at 23:45
Hi Greg
I had a 2009 patrol and fitted a Steinbauer and 3" Taipan exhaust. Reason is that I did a 3 month trip towing a 3 tonne van plus tinny on the roof. Worked ok but the hills still pulled me up, it still is only a small motor.I also fitted an after market intercooler and exhaust,boost and transmission temp gauge just to keep a close eye on everything. Without the van on it moved along really well. Cheers, Boof.
AnswerID: 598698
Follow Up By: Greg_513 - Saturday, Apr 16, 2016 at 09:39
Thank you Boof.
FollowupID: 867889
