SWAG FIBER GLASS POLES
Submitted: Sunday, Apr 17, 2016 at 06:44
macdrum
Snapped / broken fiberglass ploes does anyone have any alternatives . I have tried all types of fiberglass poles at least 4 different types & they all snap .
Reply By: Tony F8 - Sunday, Apr 17, 2016 at 07:42
Have you tried the aluminium swag poles.
598751
Reply By: Tim F3 - Sunday, Apr 17, 2016 at 07:59
have had success with using pvc conduit tubing approx 12mm dia. the same
grey tubing electricians run cables through..
hope this helps.
598754
Reply By: Member - MARIC - Sunday, Apr 17, 2016 at 11:07
Can you get carbon fibre poles they should prove more flexible and lighter, I use carbon fibre paddles for canoeing
598766
Reply By: Member - Scrubby (VIC) - Sunday, Apr 17, 2016 at 14:09
If you are talking about the "Bow " poles for a Dome Swag I obtained some fibre glass ones of a similar diameter from a mobility scooter
shop , they sell them as safety flag sticks for scooters and wheel chairs etc.
You might also get them from a bike
shop, they have them for kids bikes.
You will have to cut them to the required lengths and glue some tubing on the ends.
Scrubby.
598770
Reply By: Member - Mark (Tamworth NSW) - Sunday, Apr 17, 2016 at 15:02
Most up market lightweight tents for back packing use Aluminium poles (they bow almost as much as Fibreglass ones). I've used
mine several times over the past 5 years with no problems.
You should be able to get them at specialist
camping shops
598771
Reply By: Hoyks - Sunday, Apr 17, 2016 at 18:05
There are fiberglass poles and fiberglass poles. I had some that had all the fibers running longways. These were rubbish and had a tendency to split up the middle.
Others I got have a spiral wrap/braid around them, these seem to be a lot more robust.
Aluminium poles are good too, very light, but a bit unforgiving if they get stood on.
598780
Reply By: ian.g - Monday, Apr 18, 2016 at 11:54
You can try electric fence fiberglass posts, these can be obtained from most rural supply merchandise outlets, can be bought in different lengths and are very flexible and strong.
598806
Reply By: Wojieboy - Friday, Apr 22, 2016 at 23:26
You can buy alloy (Aircraft aluminium) ones to suit your swag. I had to replace one from a 10 year old swag and there was no OEM replacement available from the manufacturer. Went to a
camping store and sized one up- hey presto! all good. and much more durable also FWIW...
599039
Follow Up By: macdrum - Saturday, Apr 23, 2016 at 04:57
Could you let me know what
camping store you purchased alloy rods from ?
868241
