Ringing an IsatPhone
Submitted: Friday, Apr 22, 2016 at 11:44
ThreadID: 132202 Views:2432 Replies:3 FollowUps:3
This is just to confirm that it's possible to use Skype at $2.82 per minute. Much cheaper than Telstra. Some landline resellers also offer better rates than Telstra.
Also a phone without call credit can still receive incoming calls and texts as well as connect with 000.
Reply By: Sigmund - Friday, Apr 22, 2016 at 12:12
And here's a tip that's been posted before and it won't hurt to post again. From outfittersatellite.com:
Sending an Emergency Alert Message from the IsatPhone PRO Satellite Phone:
The IsatPhone PRO satellite phone has a powerful Personal Alert feature that can be sent to as many as 10 text or email recipients by simply pressing * and # simultaneously for 2 seconds from the main screen.
Before you are ready to send a personal alert a little setup is required. The alert message has the following elements:
Last GPS fix and time
Time that the personal alert was sent
Email address of recipient, if an email address was used
A short explanatory message
Use the Left Selection Key to access the Menu. Use the Center Selection and Navigation Keys to select the Extras icon. Highlight Personal Alert and press the Center Selection Key. Highlight Configure personal alert and press the Center Selection Key. You will now need to edit your recipient list and edit your personal message.
Make sure the personal message explains to your friends why they are receiving it. We recommend that you send at least one TEST personal alert broadcast so that your friends understand what they are receiving and what will be expected from them if a real emergency occurs in the future.
AnswerID: 599009
Reply By: Member - willawa - Saturday, Apr 23, 2016 at 12:07
I sent a SMS to my Isatphone that does not currently have credit ,message received OK
Then tried calling and no result.
Any clues?
Ed
AnswerID: 599057
Follow Up By: Sigmund - Saturday, Apr 23, 2016 at 12:45
'fraid not Ed.
FollowupID: 868260
Follow Up By: Sigmund - Saturday, Apr 23, 2016 at 18:46
What happened when you called Ed? Silence? Recorded msg?
If you were Skyping, you'll have seen there's no entry for Inmarsat in the country list. My daughter did the test call and entered 0011, then the satphone number. The 0011 was stripped off in the subsequent screen.
Elsewhere I've read that you can pick any country and then the satphone number only.
FollowupID: 868270
Reply By: David T6 - Saturday, Apr 23, 2016 at 18:23
I set my Isatphone up about 4 weeks ago, got sim etc. not leaving till late May. Sent and received several txt mugs to/ from, but no phone call access. Yesterday paid for call access of $85 for 3 months and now receive and transmit calls works.
AnswerID: 599065
Follow Up By: maurice b - Sunday, Apr 24, 2016 at 09:49
Hi David could you clarify please. I know you can recieve sms and emails with no credit. However a Red error would occur if you tried to sent. Cheers
FollowupID: 868283
