steeing dampers??? help
Submitted: Thursday, Apr 28, 2016 at 18:24
Member - larsy
hi everyone, hope all is
well!
i want to know everyones thoughts on steering damper.
im looking at a 35mm
bore heavy duty damper, but should i go bigger like a RTC damper!
i was also thinking of replacing my tie rod aswell, since i am alao doing my swivel hub seals and bearings.
i have had most of my bushes replace already.
oh i have a 80series.
Reply By: Member - mechpete - Thursday, Apr 28, 2016 at 19:47
hi have used a return to centre steering damper on 2, 4wds
it makes them very nice to drive , a bit lighter to steer
will put one on any future 4wds when needed
mechpete
599280
Reply By: Member - mechpete - Thursday, Apr 28, 2016 at 19:49
forgot to mention ,make sure you replace the oil seal
in both ends of the housing ,that's what causes the swivel seal to leak
mechpete
599281
Reply By: Member - ACD 1 - Thursday, Apr 28, 2016 at 23:02
Hi larsy
I'm running an RTC on my 100 series.
Boy what a difference it makes. Sand driving is a lot easier - almost like have an autopilot fitted.
Highly recommend it.
Anthony
599289
