Android Oziexplorer tracks
Submitted: Saturday, May 14, 2016 at 17:51
ThreadID: 132412 Views:2667 Replies:3 FollowUps:3
On the android version of Oziexplorer you can load a waypoint and then it has the capability to show the map at that waypoint. Can this be done if I load a track ? I can't find any go to map type of function for tracks, is there a solution?
Regards Sludgie
The scrub is something terrible. Oh, what a damnable, treacherous, God forsaken country it is to be sure. I believe it would sicken the Devil himself.
Reply By: Life Member - Fred B (ex-NT) - Saturday, May 14, 2016 at 18:08
when you load a track into Ozi, you go to the location on the map where the track is loaded. If you look at the map viewer, you will see the tack on it, then click on it and your main map will open where the track is. If you do not have a map open where the track is located you won't see it on the "view" area. Hope that makes sense?
If you click on "show track control" you can check to see if you actually have a track loaded. You can also change the colour and width of the track if it clashes with the the colour of a road etc.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 600050
Follow Up By: Life Member - Fred B (ex-NT) - Saturday, May 14, 2016 at 18:18
Sorry, gave you the PC version....
Same principal applies. on your map, zoom out until you see the location of the track. Tap on it until you have the map level you require. You must have a) loaded a track and b) show tracks turned on.
regards
Fred B
FollowupID: 869374
Reply By: Sludgie W.A - Saturday, May 14, 2016 at 19:22
Thank you for your reply Fred, my problem is if I don't know where the track is I can't scroll in or out to find the required map. I was aware of the PC way of doing it, I was trying to do it the bush with the android only. I will keep playing around for the simple solution.
Sludgie
AnswerID: 600053
Follow Up By: wombat100 - Sunday, May 15, 2016 at 19:26
Hiya Sludgie
I'm also finding the Android is 'subtly' different than the CE version- after about 10 years of using the latter !!
FollowupID: 869413
Reply By: maurice b - Saturday, May 14, 2016 at 21:17
How i do it if i was given an unknown trackfile.plt is to first load the Australian map from Hema then load the file so you can all Oz , then load a more detail map of that area of track location. Dont think there's a goto feature for tracks. You could create waypoints manualy along the track and then use go to, but use your destination waypoint as a goto so you can see you progress then zoom in and just follow your line. Ozi android still needs more development
AnswerID: 600057
Follow Up By: Sludgie W.A - Sunday, May 15, 2016 at 10:38
Thanks Maurice, I have sent an email To Oziexplorer just in case there are changes coming. The reason for the unknown tracks was just laziness on my part from not naming them. I like the waypoint idea for the start of a track.
Sludgie
FollowupID: 869381
