Rv tv aerial to run a uhf
Submitted: Sunday, May 15, 2016 at 21:29
Gold Hunter
Can a standard Rv tv aerial also be used to run a
UHF radio. If not which one would be best to fit to caravan and where would be the best place to mount it.
Hope all that makes sense.
Reply By: Member - Stephen L (Clare SA) - Sunday, May 15, 2016 at 21:39
Hi Gold Hunter
The short answer is No.
All antennas are designed to pick up different frequencies in most cased today, your atavistic reception will be Digital and UHF.
600116
Reply By: Hoyks - Monday, May 16, 2016 at 09:36
No. Antenna are manufactured to a specific length to transmit the signal at a specific wave length. Using a antenna that is he incorrect length may receive but won't be as good as it could and can lead to damaging the radio if you try and transmit.
Want to get to sleep early? have a read...
https://en.wikipedia.org/wiki/Electrical_length
600139
Reply By: MEMBER - Darian, SA - Monday, May 23, 2016 at 20:03
As I once possibly understood it, UHF antennas are built to ideally satisfy channel 40 (of the 80)...the other channels 'make do' with a near compromise. A 600mm wire is best for distance over the plains, while a 150mm stubby (1/4 wave) has good penetration in undulating terrain, but shorter on distance. But, I'm no technician.
600483
Reply By: Gold Hunter - Monday, May 23, 2016 at 20:43
Thx everyone, guess I will need to put a 'real' UHF arial somewhere on the caravan, any suggestions as to the best location.
600487
Follow Up By: Frank P (NSW) - Monday, May 23, 2016 at 20:49
Buy a ground-independent antenna and fit it at the most convenient place on the roof, having regard to cabling and access to the radio.
The roof is best. Stand-offs on a side wall will limit performance.
869861
