Article Comment: EOTopo
Submitted: Sunday, May 29, 2016 at 08:32
Member - KathyL
I purchased
EOTopo recently and, as I was planning a trip around Australia when I bought it, I took the time before I left home to download the complete map set (ie, approximately 2.3Gb of maps) to my PC before copying it to my iPad (GPS capable) and iPhone. However, when I was on Fraser Island last week (where I had no internet coverage) I discovered that Memory-Map would not display the detailed map of my current location correctly on my iPad because of a 'Communication Failed' error (the error message also reported "internet communication with map server has failed"). I am now in
Maryborough and have discovered that Memory-Map will *NOT* display the detailed OETopo maps I have installed unless I have an internet connection. I realise this is probably a Memory-Map issue (I have version 1.6.6-353 of the app installed on my iPad) but it means I cannot use the
EOTopo maps without an internet connection (which means I won't be able to use them in many parts of Australia). Does anyone know how I can resolve this issue?
Reply By: Tony F8 - Sunday, May 29, 2016 at 09:09
I have been using memory map for about 5 years now and only had that problem when I didn't download the map I wanted. Email memory map as their are very helpful and should be able to get it sorted for you
600693
Follow Up By: Tony F8 - Sunday, May 29, 2016 at 09:19
After reading your post again, I think the problem could be with the ipad, ensure you have gps enabled, and check the specs aswell to make sure it has AGPS/GLONASS.
870039
Follow Up By: Member - KathyL - Sunday, May 29, 2016 at 11:28
My iPad Air has 4G/GPS functionality, I'm certain I have the maps properly downloaded and location
services is definitely enabled for Memory-Map. When I start Memory-Map without having internet access the map does not display correctly and I get the error message. However, when I start Memory-Map with internet access the same map *immediately* displays correctly without any data being downloaded - it's as if Memory-Map wants to check the map server every time I move to a different part of the map. As a result of the Memory-Map issue I ended up having to use an old version of MudMap on Fraser Island last week and it performed flawlessly.
870044
Reply By: Kevin S - Life Member (QLD) - Sunday, May 29, 2016 at 14:14
I too use EOToppo on Memory Map, without problem, provided that I have downloaded the correct section of the map. I used it on Fraser Island without problems about a month ago. I use an Android Nexus pad.
Like the man said, email MemoryMap. They are very helpful.
Cheers, Kevin
600704
Follow Up By: Member - KathyL - Sunday, May 29, 2016 at 18:12
Thanks - I'll contact Memory-Map and let you know if the issue can be resolved.
870049
Reply By: Member Kerry W (WA) - Sunday, May 29, 2016 at 19:07
If you have problems call Adele in the EO
Shop she is brilliant.
| Kerry W (Qld)
-Helen KellerLifetime Member My Profile My Blog Send Message |
600715
Reply By: Member - Jim B8 - Sunday, May 29, 2016 at 19:22
I had no real joy with Memory Map until I deleted it. That fixed it.
The constant checking of license went on regardless of how or what I downloaded.
I now use Samsung (Andriod) with ozi for Android, EO maps, and its amazing. One download, and its no dramas from there
600716
Reply By: Michael H9 - Sunday, May 29, 2016 at 19:33
Perhaps you downloaded the maps to a folder on your ipad that Memory Map doesn't recognize? By that I mean, the folder is in a folder location that Memory Map doesn't search by default. You can easily check what maps are on the device by using the "more maps - all maps on this device" menu options and see what maps are listed.
600717
