can 33 inch tyres fit a gq with a 50 mm lift
Submitted: Friday, May 28, 2004 at 22:21
ThreadID: 13257 Views:4035 Replies:6 FollowUps:0
gday all just wondering if 33inch tyres fit on my gq shorty with 50mm of lift.
have been told i have to take my factory flares off is this true
Reply By: Member Eric - Friday, May 28, 2004 at 22:58
they will fit and automaticly take off your flairs lol . with flairs go for 32's . Much better fit , with one inch body , you can fir 33 's
AnswerID: 60721
Reply By: hof - Friday, May 28, 2004 at 22:59
G'day, got a LWB GQ with factory flares 50 mm lift 32" tyres and they just touch sometimes. You could have problems with 33"
AnswerID: 60722
Reply By: Truckster (Vic) - Friday, May 28, 2004 at 23:59
If you take the flairs off your tires will stick out and instant defect.
You can fit 33's on a 3inch lift with OEM flairs, mate has them on his, but depends on the offset of the rims. I think you could fit with 2inch but would hit on guards everywhere. My 33's hit on chassis with 6inch lift... so 2in.. Funny though, my JT's hit less than the MTR's do, JTs are 34x11.5, but recommend 9inch rim
Are you talkin of 33x12.5 or 33x10.5's?
Then again if you remove the mudflaps, and trim guards a little you can fit Q78's (36's)
AnswerID: 60732
Reply By: duncs - Saturday, May 29, 2004 at 11:47
My old GQ had 33 on when I first set eyes on it but the previous owner kept them. The car had a 2" suspension lift an 1" body lift. TEh OE flares had been trimmed at the bottom and the mud flaps removed to allow for full lock. Apparently had no problems.
See mid 90's OVerlander Mags for pics of white GQ with red bar work.
Duncs
AnswerID: 60753
Reply By: Member - Brian (Gold Coast) - Sunday, May 30, 2004 at 07:37
Our GQ has 2" lift and we have no probs with 33 X 12.5's.... except at full articulation they rub, but not a lot. Not sure what the offset on the wheels is... and we took the flaps off ad run the wider rubber flare kit. Hope this helps
AnswerID: 60854
Reply By: phil - Monday, May 31, 2004 at 15:53
Don't forget the engineering certificate that is required to make it legal.
AnswerID: 61026
