Auto electrician Townsville
Submitted: Saturday, Jun 25, 2016 at 19:41
ThreadID: 132852 Views:2678 Replies:5 FollowUps:0
Hi from tropical Townsville.
Wanting to add second house battery to motor home. Can any locals recommend
A reputable auto electrician?
Thanks in advance, cherry.
Reply By: Peter C61 - Saturday, Jun 25, 2016 at 21:59
Hi Cherry, Why not do it yourself. Make sure the new battery is mounted securely. Have a couple of appropriately rated cables made up or do them yourself and connect. Make sure the batteries are of the same rating, for example 100 amp/ hour 12v. To my knowledge if the batteries are inside the vehicle you cant use led acid batteries because of the gas they vent. I have used two 110 amp/ hour agm batteries as they are completely sealed and can be installed upside down if necessary and can never leak. Hope this helps.
AnswerID: 601816
Reply By: swampy - Sunday, Jun 26, 2016 at 00:21
hi
Autolek owner Troy
no.3 Carrol st. mt Louisa , Townsville
mob 0419 463 071
As you would expect there are a few less than reputable auto leckys in Town [some sparkies in town who i would not give a lawnmower to and charge heavily ]but Troy is a good bloke with a good rep . I have used him on a few occasions when I did not have enough time .
swamp
AnswerID: 601818
Reply By: William 1 - Sunday, Jun 26, 2016 at 09:20
Quickstart or Leslies have both given me good service.
AnswerID: 601827
Reply By: HKB Electronics - Monday, Jun 27, 2016 at 13:07
Seems the others have covered the auto elects, my question would be why are you adding the extra battery, most likely your running running out of power but keep in mind you need to be able to charge the extra battery so make sure the charging system is up to it.
AnswerID: 601867
Reply By: Member - kyle46 - Monday, Jun 27, 2016 at 20:21
quickstart,
AnswerID: 601892
