Article Review: ExplorOz Traveller Feedback & FAQ
Submitted: Tuesday, Jun 28, 2016 at 21:51
Member-George (WA)
My Article Rating:
On my Profile>My Tracking, showing 2 active entries.
1) EOTrackMe Android, is showing actual roads travelled from start to finish.
2) EOTraveller(Android), is not showing any tracks at all. However, whilst we were driving it did show the black arrow with blue flashing ring, following our roads from start to finish. Using online maps but, at times, switching between online and off line maps.
My question, should "My Tracking" for EOTraveller also show the actual roads travelled from start to finish, as per the EOTrackMe entry ?
Reply By: ExplorOz - David & Michelle - Wednesday, Jun 29, 2016 at 17:42
Yes George it should however I suspect you are using an older Android version in the 4.x range is that correct? I have just published 1.8.7 which should solve this as the older Android V4 devices do not seem to correctly support the intelligent movement detection system that we are using the the Track Logging system.
See what happens with 1.8.7 and let us know how you get on.
David
601962
