Head lights
Submitted: Tuesday, Jul 26, 2016 at 22:09
peter r14
Has anyone put a set of jw speaker leds in a 200 series? if so, do they fit easy at the back of the light as I think it will be a tight fit.
Reply By: TomH - Wednesday, Jul 27, 2016 at 11:43
One thing to remember with headlights is that the reflectors are designed to work with the installed bulbs.
Changing them for something else is fraught with problems and may not even be legal.
IE. Putting HID bulbs in standard enclosures. Due to the different length the filament extends from the housing the focus goes to hell and flaring and glare can be the result. It is also illegal to retrofit HID's of over 2000 Lumens unless you have washers and a levelling system.
Maybe the same with LED but mostly it is illegal to fit anything that is not fitted to one of the models of the vehicle
602819
Follow Up By: Member - mechpete - Wednesday, Jul 27, 2016 at 15:33
Couldn.t have said it better myself
Mechpete
872459
Reply By: Member - Stuart P (WA) - Thursday, Jul 28, 2016 at 08:05
the speaker leds need a little room behind the headlight , there may not be the room behind battery and headlight , being led you may be dissapointed with the light they throw out
602846
