Iridium Go
Submitted: Monday, Aug 01, 2016 at 07:12
Member - Boobook
Has anyone used an Iridium Go sat phone with a Telstra SIM successfully?
I know others such as 9505, 9555, 9575 etc work
well. I am thinking of getting an Iridium Go which is a little different.
Reply By: Member - William B (The Shire) - Monday, Aug 01, 2016 at 11:25
Hello Boobook,
I had not heard of the Iridium Go before so had a look.
It seems to me that the Go pairs with the mobile phone and you don't need another sim card the Go acts between your phone and the satellite.
Is that correct or have I missed something. (not unusual for me)
William
603013
Follow Up By: Member - William B (The Shire) - Monday, Aug 01, 2016 at 11:29
Ahh.
I see now.
The unit comes with a sim card, I only saw that when I went on the buy it section.
It wasn't obvious to me originally.
William
872654
Follow Up By: TomH - Monday, Aug 01, 2016 at 11:38
It has its own sim card because that card registers it on the Iridium network. It uses WIFI to the phone to pick up updates and your contacts so it knows who to dial on the Satellites network
If you google it there is a very good instruction PDF from Telstra on how to set it up and how it works.
It apparently needs its own sim to work but maybe would work with a spare Telstra postpaid one Only way to find out would be to try it but after looking at its setup probably need one of its own.
872655
Follow Up By: oldsalt - Monday, Aug 01, 2016 at 11:51
Another similar device you could check out is the "Optus Thuraya SatSleeve +" and the "SatSleeve Hotspot"... seem to be much the same...
872656
Follow Up By: Member - Boobook - Monday, Aug 01, 2016 at 12:52
Thanks everyone, I am specifically interested in the Iridium one as I want to use it in the Victorian High country as
well as further north. I also read that the Go is compatible with the next generation Iridium network scheduled for 2017 release.
872658
Follow Up By: Member - Andrew W14 - Thursday, Aug 04, 2016 at 20:43
I have Iridium Go ( with its own SIM and number) And WiFi linked to my iPhone 6S. Via Telstra. System works very
well, but expensive to use. Overall though a good alternative to full cost of buying a full Sat phone.
Please realise like any Sat phone it has to see the satellite and the Iridium ones are not geo stationary and you may have to wait for it to pass over your location. Like all they only work
well in open spaces.
872759
Follow Up By: Member - Boobook - Friday, Aug 05, 2016 at 07:56
Thanks Andrew.
I really just want to use it as an alternative to my old 9505. That works ok but the texts are very clunky and I the main appeal of the Go is that I can mount it to the vehicle and have it in postion to make and receive calls when driving. That is a with hard with the phone.
So is the SIM a normal Telstra mobile SIM or a specific Satellite provider one ( like Pivotel etc)?
872770
Follow Up By: Member - Andrew W14 - Friday, Aug 05, 2016 at 09:24
It's a normal Telstra SIM. If you do get one ask for a spare SIM as I had a bit of trouble with
mine initially.
872772
Follow Up By: Member - Warren H - Saturday, Aug 06, 2016 at 07:47
Does this mean that the phone only serves as the interface, so you could swap the sim out of the phone into the unit (with appropriate caddy if required)?
872797
Follow Up By: Member - Boobook - Saturday, Aug 06, 2016 at 07:56
On the surface that should work if the Telstra Sim works in the Iridium Go Warren.
The downside of that though is
1)The SIM adfapters tend to be dodgy and fragile at times, take quite a few with you.
2)In my experience, when you put your normal phone number SIM into the Sat phone while out of coverage, you get a whole lot of texts and missed calls. At $1.50 a pop, and you often can't tell if it is a loved one with an issue or a telesales call until you get them all and sometimes call the number. You can get the $10 plan for as short as a month, so no one will call that number and you can stop it after the trip
3)The benefit of the Go to me is that you can set it up in your car and leave it on at no cost. Then calls are easy to make / receive.. That advantage goes away if you swap sims and a normal cheaper Sat phone may achieve the same thing ( ignoring data)
872798
