Fuel supply issue 100 series toyota
Submitted: Tuesday, Aug 09, 2016 at 13:08
Richard N2
I have a 2002 100 series land cruiser, runs on LPG and sub
tank but not main
tank.
is it most likely to be the
fuel pump or relay.(6 cylinder petrol) this is issue started in the last week.
Reply By: TomH - Tuesday, Aug 09, 2016 at 13:23
Have heard of this and the remedy was a new pump for mega dollars.
A look on Lcool may find a cheaper solution You have to join for free but is all things Toyota
603228
Follow Up By: Life Member TourBoy, Bundaberg - Tuesday, Aug 09, 2016 at 16:41
Fuel pumps for the FJZ105 and UZJ100 range from $50 to $150 depending on brand
872892
Follow Up By: TomH - Tuesday, Aug 09, 2016 at 20:48
My mistake The fix for the diesals, at least is a new instrument cluster at about $1600.
Couldnt find much info on Lcool about petrols for you but maybe the same problem
872898
Reply By: Bob Y. - Qld - Tuesday, Aug 09, 2016 at 14:05
Do the petrol 100's have
fuel tank changeover solenoids like the diesels? Perhaps one of them has spat the dummy.
603229
Follow Up By: Life Member TourBoy, Bundaberg - Tuesday, Aug 09, 2016 at 16:27
No The petrol 80/105's pump from the rear to the front
tank
872891
Reply By: Allan B (Member, SunCoast) - Tuesday, Aug 09, 2016 at 22:43
Richard,
The fault could be with the control switch, pump, relay, loom connectors or even the cabling.
Without troubleshooting competence you would be wise to consult an auto-electrician before making guesses.
603249
Reply By: Richard N2 - Wednesday, Aug 10, 2016 at 10:06
thank you for your comments.
has given me some areas to work on.
603260
Reply By: Malcom M - Monday, Aug 15, 2016 at 12:33
