EGR Blocking plate, Oil cooler for Auto Trans
Submitted: Monday, Aug 29, 2016 at 21:03
ThreadID: 133336 Views:4118 Replies:3 FollowUps:2
Sometime ago I bought online and EGR blocking plate and upper crank case breather kit. i have lost details of where to buy these. Does anyone know where to get them now.
Secondly I am told that an oil cooler for my 200 series L/cruiser's auto gear box is "essential" as I do a lot of towing with my 3 1/2 ton van. What is the consensus on this?
Reply By: Gone Bush (WA) - Monday, Aug 29, 2016 at 22:58
You can get EGR plates on Ebay, not sure about breather kits.
Re the gearbox, just tow in S4 and temps will stay around 60 degrees.
If you tow in S5, S6 or D, temps will be at least 20 deg higher.
No need for a cooler.
AnswerID: 603956
Reply By: Member - KeithB - Tuesday, Aug 30, 2016 at 00:28
There's already a big transmission oil cooler on the 200 series. But mine still got over 100 degrees and even more tow in in low range. I installed a Richards Transmission Lockup kit and it dropped the temps by 10-30 degrees and stopped the cruise control from hunting through the gears as well. Saves fuel too.
Keith
AnswerID: 603959
Follow Up By: Echucan Bob - Wednesday, Aug 31, 2016 at 07:56
Does the 200 series have a transmission temp gauge as standard? I have fitted external gauges to my atf and coolant lines in LX470 and Land Rover.
FollowupID: 873635
Follow Up By: Member - KeithB - Wednesday, Aug 31, 2016 at 09:39
No transmission temp gauge on the 200 series. But you can set a Scangauge to read it.
FollowupID: 873639
Reply By: Member - Racey - Tuesday, Aug 30, 2016 at 08:37
I find towing in 4th overcomes all the hunting problems. Only shift to 5th if the conditions are right, usually no head or side winds.
AnswerID: 603963
