Dump point (fitting etc)
Submitted: Saturday, Sep 03, 2016 at 12:51
duck
have not used many dump points & new camper has a large black/
grey water tank 100ltrs & has its own pump & std cam-lock fitting , what is std or is there no std? about to drive to WA from NSW
Reply By: Member - Rod N (QLD) - Saturday, Sep 03, 2016 at 15:18
All the dump points I have used do not have any hose fittings, just a hole. The majority of these are the blue ones usually sponsored by CMCA. The very few that have fittings have been at caravan
park sites on large pipes, 2 or 3 inch?? My cassette outlet fitted inside them.
604072
Follow Up By: duck - Tuesday, Sep 06, 2016 at 18:31
thought that would be the case just wanted to make sure as the local one is used by boat owners & motor homes but it is a cam-lock & you can use it if you have a cam-lock you also have the choice to use its pump or your own,
873855
