Wildflowers in WA blooming
Submitted: Sunday, Sep 04, 2016 at 11:31
Hilux fan
If you're in the area.
http://www.abc.net.au/news/2016-09-04/wa's-mid-west-awash-with-colour-with-the-best-wildflower-seas/7811986
Reply By: Member - Rod N (QLD) - Sunday, Sep 04, 2016 at 12:04
I can't get the link to open. May I suggest you use the 'Link' button below the message box and the use the 'Preview' button and click on your link to make sure it works before you 'Submit' your post.
604093
Reply By: Member - ACD 1 - Sunday, Sep 04, 2016 at 12:18
Try this one:
ABC News Wildflower link
I just copied and pasted into my browser - including the bit that was not underlined.
Anthony
604094
Follow Up By: Hilux fan - Sunday, Sep 04, 2016 at 12:52
Not usually a problem but I'm suspecting if the link text is more than 1 line long then the second line doesn't get picked up as part of the link.
873779
Follow Up By: Member - Rod N (QLD) - Sunday, Sep 04, 2016 at 13:12
G'day Hilux fan. It appears that if the link text is even less than 1 line then it will not work. If you look at the link you posted you will see only part of it underlined and if you hover over it that part will highlight, this is the part that will open in a new tab/page.
873781
Follow Up By: Hilux fan - Sunday, Sep 04, 2016 at 13:17
I can see the problem now. It doesn't like apostrophes (in wa's). Must cause a break in the link setup.
873782
