Friday, Sep 16, 2016 at 11:54
You don't know, unless you have carried out extensive research. The road and track system in Australia is a bureaucratic nightmare.
Every State has a different road control system, there are 100 different authorities and heirarchies controlling roads and tracks and land access throughout Australia.
Pastoral area roads are public roads, but pastoralists have the right to restrict public access to their properties and
infrastructure.
Accordingly, it is good manners to visit station homesteads upon entry to stations to find out the station owners rules and to let them know why you are there.
They often have rules covering station visitors and travellers behaviour. Shutting gates, or leaving gates as you find them, is just one rule.
Bottom line is, as the leaseholders, they are responsible for the condition of the property and improvements, and undesirable visitors have been known to cause damage to both - and then depart without trace.
Then you have privately-owned and privately-constructed roads such as on mining areas, or across Crown Land, and/or giving access to rail or other
infrastructure. These are generally clearly signposted.
The Aboriginal Land roads access is controlled by the Aboriginal communities, Aboriginal Councils, or the relevant State Aboriginal Affairs Dept.
Once again, each State is different when it comes to Aboriginal road control.
It's generally widely understood today that roads across Aboriginal Lands require Aboriginal authority permission to traverse them.
This is because Aboriginal Lands are essentially freehold land.
In W.A., roads through Aboriginal Lands are regarded as public roads, with conditions (permits) applied.
This is no different to the cities where occasionally, an important laneway is privately-owned freehold land - yet the owners are obliged to give the public access to the laneway for 364 days of the year, with the owner being obliged to totally restrict public access, on one day of each year, to show and retain freehold ownership of the laneway.
General rule of thumb - if a road is not signposted as private, or fitted with a
locked gate, it is open to the public - or until you are challenged by someone.
When that someone challenges you, you'd better have superior knowledge of the road/track ownership authority in the region, than they do.
As previously stated, asking local authorities is a good start, if you intend to traverse a track where the status is in doubt.
The Police regard a "public road" as a maintained road whereby the public can access it easily, and it is not gated - and/or the public have been invited into that area.
Insurance claims and road casualty statistics often wrangle over whether an accident was on a public road or on private property.
In general, freehold land is regarded as private property, and access roads to the likes of homesteads on freehold land, are regarded as private property, and not public roads.
If a road is regularly maintained, and not gated, this normally would indicate it is a public road - but even this is not a hard and fast rule.
There are many public roads and tracks that are not maintained, yet keep their public road status.
Unmaintained tracks through unallocated Crown Land are rarely regarded as public roads.
Nearly all Crown Land today has been allocated a status, such as
Park, Reserve, Forest, or other defined use - so an authority has been appointed that also controls vehicle movement across that particular piece of land.
Cheers, Ron.
604449
