2011 Toyota VDJ79 Sub Tank relay
Submitted: Wednesday, Oct 12, 2016 at 22:00
ThreadID: 133593 Views:10203 Replies:3 FollowUps:3
Does anyone know where subtank relay on a 2011 Toyota single cab VDJ79 is located? It is the relay that is turned on via the sub switch, which then activates the 2 fuel solenoids. I have gone onto the online Toyota manuals and can find no reference to it's location
Thanks Kevin
Reply By: TerraFirma - Wednesday, Oct 12, 2016 at 22:05
You may find your answer or at least more information in this thread.
Sub Tank Relay
AnswerID: 605082
Follow Up By: 116hynes - Wednesday, Oct 12, 2016 at 22:17
Thanks for the reply, the link is about the solenoids, not the relay that drives them. Also the 2011 model is the one with airbags and the dash layout is different.
Kevin
FollowupID: 874874
Reply By: Malcom M - Thursday, Oct 13, 2016 at 07:05
Have you tried Lcool.org?
Repository of all Toyo 4WD knowledge.
The Haynes type manuals are also good with lots of pics. Do you have access to one of them?
AnswerID: 605085
Reply By: vk1dx - Thursday, Oct 13, 2016 at 09:22
How about you getting under the car and get someone to operate the "SUB" switch in the cabin. I don't know if this will work but you may hear both the solenoids and the relay. Just chase the noise!
A bit outside the box but it may help.
Edit:: Not your model but I found this on a forum at iH8MUD;
Solved!
Went to an electrician... he made a hot wire connection somewhere in the fuse box, disconnected the battery for twenty minutes, put it back, and the sub tank worked!
He told me there must have been a short somewhere, the control unit decided to shut off this section, until further reprogramming.
Thanks for those who tried to help.
AnswerID: 605087
Follow Up By: 116hynes - Thursday, Oct 13, 2016 at 11:23
I am putting a rear fuel tank into a single tank (factory option) cruiser. I have located position of missing relay and will post if anyone is interested.
Thanks for everyones replies.
Kevin
FollowupID: 874877
Follow Up By: vk1dx - Thursday, Oct 13, 2016 at 12:16
Excellent Kevin
You may want to post in the main thread. Replying to my post may only send a copy to me.
FollowupID: 874880
