Mazda Bt50 XTR & Hema maps
Submitted: Monday, Oct 24, 2016 at 14:18
ThreadID: 133656 Views:7780 Replies:1 FollowUps:3
Question for BT50 owners. Has anyone had Hema Maps loaded into the onbord gps and what do you think. Is it worth it.
Reply By: Member - WBS - Tuesday, Oct 25, 2016 at 07:01
Hi Errol
You will find that the Hema Maps are already loaded onto the micro SD card. Take the Micro SD card out of your Mazda media device and browse its contents on a PC and you will see what I mean.
What you need is the code to unlock the Hema app to get it to work. That will cost you around $200 to get unlocked by your dealer - a license fee I suppose they would call it.
I tried to activate the app through the menu system but failed miserably.
WBS
AnswerID: 605387
Follow Up By: Member - WBS - Tuesday, Oct 25, 2016 at 07:15
Errol,
I've sent you a message as a follow up
WBS
FollowupID: 875132
Follow Up By: Member - Errol (York WA) - Tuesday, Oct 25, 2016 at 15:14
Cheers WBS. I didn't even know that there was a card in it. Carn't find your massage though. Errol
FollowupID: 875147
Follow Up By: Member - WBS - Tuesday, Oct 25, 2016 at 20:08
If you haven't already discovered it the Micro SD card is stored behind the flap labeled CARD directly below the PWR/VOL dial.
Basically, if you plug the Micro SD card into your PC and find the OziExplorer/Maps/ directory, you can download the map and image files (.MAP and .OZF4 files) and use them with OziExplorer.
WBS
FollowupID: 875157
