200 series L/C
Submitted: Wednesday, Nov 16, 2016 at 09:24
Member - Rod Bill
has anyone encountered the following after changing
fuel filter; fault lights remain on; malfunction,
fuel system, 4wdlo, esc.
Reply By: raincloud - Wednesday, Nov 16, 2016 at 09:34
Try this: Turn off ignition, Disconnect warning light plug from
fuel filter' restart motor, reconnect warning light plug to
fuel filter. Should solve problem.
605925
Reply By: Member - Rod Bill - Wednesday, Nov 16, 2016 at 09:40
did the filter change as recommended regarding disconnecting lead on top of filter body ,no joy
605926
Reply By: Member - John F (VIC) - Wednesday, Nov 16, 2016 at 10:26
agree with raincloud's advise
605927
Reply By: Member - Racey - Wednesday, Nov 16, 2016 at 10:28
I thought it may be useful to note this here for the benefit of owners as it is a little annoying not having the information readily available.
Follow this procedure to turn light off:
1. Disconnect top wires/plug on filter housing
2. Turn Ignition Key on
3. Plug top wires/plug back in
4. Turn Ignition Key off
5. Turn Key back on and start vehicle
Light should now be off!!
I hope this is of some assistance.
Jon
605928
Reply By: Gronk - Wednesday, Nov 16, 2016 at 17:32
And next time to save any hassle, don't disconnect any plugs or wires when changing a filter.
Undo the top allen head bolts, lay the top filter housing on a clean rag, lift up the filter and wait for it to stop dripping, put new filter in and reattach top filter housing.
But have to say, even after disconnecting plugs etc, you should only have the
fuel warning light on, not any of the others ??
605941
Follow Up By: Member - Rod Bill - Wednesday, Nov 16, 2016 at 18:34
Thanks for the comments ,seems my troubles relate to an after market performance chip , once removed and computer reset all good ,no more light issues.
875731
