Extended leaf shackles ra rodeo
Submitted: Saturday, Nov 26, 2016 at 03:10
spaanderman65
Hey everyone i have bought some extended leaf shackles for my rodeo. One side of the leaf shackle is thinner than the other. Therefore once fitted there is a 15mm gap at the top where it mounts to the chassis. Does this matter?
Reply By: MUZBRY- Life member(Vic) - Saturday, Nov 26, 2016 at 06:59
Gday
If the new shackle is not the same width on both ends as the old ones , you have the wrong shackles.
606228
Reply By: Athol W1 - Saturday, Nov 26, 2016 at 07:24
spaanderman
Yes it does matter.
Shackles that allow for any side movement will allow the spring pack to move freely across the vehicle which will have an effect on steering stability.
Also to consider when fitting any non genuine spring shackles is the effect that this change will have on drive line angles, as it can cause driveline vibrations or failures.
Also, and possibly the most important consideration, is the effect that any changes that are made to the length of the spring shackles has on the
suspension roll centre, as this change can introduce adverse vehicle handling effects.
There are quite legitimate reasons as to why the authorities consider them to be an illegal modification.
Athol
606229
Follow Up By: Shaker - Saturday, Nov 26, 2016 at 12:28
Not to mention the insurance company!
875939
Reply By: TomH - Saturday, Nov 26, 2016 at 08:47
Take them back they are illegal for a start.
606230
Reply By: Jackolux - Saturday, Nov 26, 2016 at 08:57
Why do you want extended shackles , to lift the rear up a bit I guess . Do it properly with some new springs .
606231
Follow Up By: Member - mechpete - Saturday, Nov 26, 2016 at 13:11
I,m with you ,
another person who doesn,t know much about what there doing
goin for the cheap fix
cheers mechpete
875940
Follow Up By: Paul E6 - Saturday, Nov 26, 2016 at 13:36
Couldnt resist could you.
875941
Reply By: RMD - Saturday, Nov 26, 2016 at 14:28
They are just shackles. Extended leaf???? Extended shackles "YES".
The sides are usually a plate each the same thickness.
The width of the shaft section is what is being described in a round about way.
The width/length of shaft should be the same for an RA. Some other makes do use offset shackles for some unfathomable reason.
As stated above, No side gaps should exist.
Longer shackles than STD are illegal. It creates a larger sideways leverage on the fixed bush which is welded to the chassis. That is not desirable.
606236
Reply By: Batt's - Sunday, Nov 27, 2016 at 00:29
Maybe they gave you the wrong one's double check the model and see if they can be exchanged. Also you should probably check what else they're going to throw and see if you need to change other items to fix any issues could be brake line diff breathers
suspension alignment the angle the spring hanger sits at is very important as
well. Yes as mentioned above they are illegal but people have been using them for years 4WD outlets have been fitting and using them for a long time as
well and they are safe to use if everything else lines up just my opinion no feedback needed on my opinion thanks. In the late 80's a few of us to made our own at work to suit our 40ser cruisers but we doubled the thickness of the plates to 10mm for strength and used high tensile bolts with new rubber bushes they worked
well I changed
mine back out when I sold the vehicle. I personally don't have an issue with them but some do so it's up to you of you fit them or not.
Do you currently have a lift kit under the vehicle. Are you just looking for a bit more height from a standard
suspension setup or compensating for sagging springs.
606237
Follow Up By: Ross M - Sunday, Nov 27, 2016 at 15:06
Batts, Why no opinion on your opinion? This is the land of free speech. While everyone survives without accident/component failure everything is ok. Isn,t it?
875965
Follow Up By: Paul E6 - Sunday, Nov 27, 2016 at 23:43
I guess it means he doesn't want to get into a thing with any campfire experts.
875972
Follow Up By: Batt's - Monday, Nov 28, 2016 at 04:08
Ross Land of free speech what country do you reside in can't be Australia because you may offend someone in public if you speak your mind these days. But that's another story.
Probably because I didn't direct my reply by insisting he doesn't use an illegal item so not interested in all the goody two shoe replies from people on that subject who have never broken the law or so they say that is all. Now back to his spring hangers.
875973
Follow Up By: Batt's - Monday, Nov 28, 2016 at 04:11
Paul a campfire shame on you not with all this global warming going on we just sit around an led light these days tapping on our mobile phones not actual conversations going on but that's another story lol.
875974
Follow Up By: Shaker - Monday, Nov 28, 2016 at 08:30
There is a possibility that the OP didn't know that it's an illegal modification, so it may have been doing him a favour.
875978
Follow Up By: Paul E6 - Monday, Nov 28, 2016 at 23:09
Ha, im not likely to be found playing with my mobile at a campfire or anywhere, I don't even carry it with me most of the time. Only for work in an emergency.
876012
Reply By: alsmithmdi - Tuesday, Nov 29, 2016 at 07:56
Bad news, waste of money . $1000 for a new heavy duty set of springs including top gas shocks. I am sure I have read, that where these extended leaves end (opposite end to the shackle) can cause crack in the chassis. If you have towed heavy load eg van, and the nose of the tug went up and the tail down, chanced are the current spring pack is damaged.
606290
