Winch battery,, which one?
Submitted: Thursday, Jun 03, 2004 at 12:45
GeeTee
Hi all, I have just fitted and electric winch and would like advice on which battery to connect it to. I have a dual battery set up ( Arrid ie. batteries not paralleled )
Regards GeeTee
Reply By: Truckster (Vic) - Thursday, Jun 03, 2004 at 13:25
What sort of car?
Exide Extreme is VERY good..
61492
Follow Up By: GeeTee - Thursday, Jun 03, 2004 at 20:09
Hi Truckster, Winch is a Warn Magnum 9000 fitted to Prado 3l turbo diesel. Had an Exide Extreme but died after about a year, no reason ... not over or under charged, used for Chescold and thats about it.
GeeTee
323038
Follow Up By: Mad Dog (Victoria) - Thursday, Jun 03, 2004 at 22:36
Maybe been cycled too deeply once too often. Thats the problem, cranking batts don't like a deep discharge, need a deep cycle for that but some find they accept a charge too slow. Hybrid batts which I think the extreme is don't do anything very
well. Don't you get a 2yr warranty with it.
323066
Follow Up By: Truckster (Vic) - Thursday, Jun 03, 2004 at 22:59
Mate I 4b with has had his 2 yrs, not a problem...
323073
Follow Up By: Mad Dog (Victoria) - Thursday, Jun 03, 2004 at 23:43
Would depend on how it's used. I couldn't imagine it lasting long if deep cycled often. I thought my blasted cranking battery was in good nick also till yesterday when it failed. I suspect a mechanical failure from vibrations. I'm pleased it went south, just a cheapo that came with the vehicle.
323079
Reply By: srowlandson - Thursday, Jun 03, 2004 at 13:27
Main battery (Cranking)
It is used to the Deep Discharging and will get the bulk of the Alternator Charge.
Steve
61494
Follow Up By: GeeTee - Thursday, Jun 03, 2004 at 20:06
Thanks Steve, Thats the way I was thinking. Guy's that fitted the winch gave me the option of either .. their call was the secondary. Will swap over tomorrow, leads are long enough.
GeeTee
323035
Reply By: Member -Bob & Lex (Sydney) - Thursday, Jun 03, 2004 at 16:32
Steve's right , cranging battery & use with engine running as it uses heaps of power
61519
Follow Up By: GeeTee - Thursday, Jun 03, 2004 at 20:10
Thanks for
the tip. Makes sense to keep the engine going ! !
GeeTee
323040
Follow Up By: Cruza - Friday, Jun 04, 2004 at 09:46
Are there any safety issues with keeping the engine running while using the winch? I thought it would make sense to leave it running but thought that was too obvious and must be unsafe or not recommended?
323112
Follow Up By: Member -Bob & Lex (Sydney) - Friday, Jun 04, 2004 at 15:52
Just have someone steering
323164
Reply By: Member - DOZER- Saturday, Jun 05, 2004 at 16:30
Gday
Another starting battery is best for a winch. They draw 3-400 amps at full load. Another good thing is a smart solenoid that joins both batteries when the winch is motored in.
Keep the motor running if you can.
Andrew
61840
