battery fuel pump
Submitted: Tuesday, Jun 20, 2017 at 09:01
ThreadID: 135110 Views:4095 Replies:5 FollowUps:2
Does anybody know where I can get the portable fuel pump that takes D-sized battery's, saw one used the other day & the owner said he saw it used on Pat Callinan's 4x4 show & found it in a shop in Brisbane but could not give me anymore info about it,
It was a little ripper of a pump for jerry cans
Reply By: Batt's - Tuesday, Jun 20, 2017 at 09:17
Just type in fuel transfer pump an image of a 12v jerry pump is there
AnswerID: 612001
Reply By: Ron N - Tuesday, Jun 20, 2017 at 11:48
Just search on eBay using "fuel transfer pump battery operated".
Be aware that any battery-operated fuel transfer pump is going to be fairly limited in its pumping ability - and all sellers appear to advise against pumping from ground level into tanks.
They advise that raising the jerrycan to the same level as the tank, is needed to get a satisfactory flow rate.
http://www.ebay.com.au/itm/BATTERY-POWERED-FUEL-TRANSFER-SIPHON-PUMP-Intake-32mmx465mm-10-Lpm-Fit-Jerry-Can-/182127192457
Cheers, Ron.
AnswerID: 612004
Reply By: Doc - Tuesday, Jun 20, 2017 at 17:42
Go-kart shops sell them, as they are quite commonly used in the sport.
AnswerID: 612006
Reply By: Member -Pinko (NSW) - Tuesday, Jun 20, 2017 at 18:09
ebay.com.au/itm/MOUNTABLE-BATTERY-POWER-FUEL-TRANSFER-PUMP-9Lpm-AUTO-CUT-OFF-Fit-Fuel-Jerry-Can-/172240907926?_trksid=p2385738.m2548.l4275
AnswerID: 612008
Follow Up By: Zippo - Wednesday, Jun 21, 2017 at 08:23
4xAA batteries? 9L/min is going to require a lot of gravity assistance.
FollowupID: 882082
Reply By: duck - Wednesday, Jun 21, 2017 at 10:08
Thanks all
picked one up yesterday & for what I want to use it for, it works well (For how long ?)
AnswerID: 612013
Follow Up By: Ron N - Wednesday, Jun 21, 2017 at 13:26
Duck - Yes, one has to remember that virtually all Chinese-made products are built to meet the lowest price for that product - and you nearly always get exactly what you paid for.
A pump being powered by torch batteries means that, either the pump output will be pretty low, or the pump will eat batteries like there's no tomorrow.
You'd be well advised to use only alkaline batteries, and I've found that Duracell Ultra D Batteries, available in a set of 2 from Bunnings for about $7.00, are the most durable of all the D cell batteries.
Cheers, Ron.
FollowupID: 882086
