Friday, Sep 01, 2017 at 07:45
The SA Parks section is generally open from mid March to end November.
For a normal SA desert crossing (French Line, WAA Line, or Rig Rd), any time early May though to say late Aug is fairly safe.
You can go outside this on what I call shoulder season, and strike it lucky with good weather and lower numbers of flies, but anything approaching uncomfortable heat will make a crossing a little bit less attractive to many people not used to the heat and flies.
You also need more
water and contingency allowances due to more fluctuations in conditions.
Maybe avoid Queens Birthday long weekend (Finke Desert Races) in June, the Big Red Bash concert usually in July, and the
Birdsville Races in Sept, unless they are of interest to combine, as
the desert traffic can get very busy both before and after these events.
Also go outside school holidays if they can be avoided.
If first crossing, I'd recommend just do French Line, the most direct and popular route, but all of them have their advantages, WAA a little less undulating on sections, Rig faster, all depends on objective.
To assist with camper info, you'd need to advise where you're coming from / heading after.
613431
