Hayman Reece 800lb weight distributor hitch, straight taution bars
Submitted: Monday, Sep 04, 2017 at 15:06
TheMajor
Looking for new or second hand taution bars, the older straight bars not the ones with a shaped end. I recently broke one in half when accessing a service station driveway. Any help would be appreciated.
TheMajor
Reply By: RMD - Monday, Sep 04, 2017 at 19:43
Are they Torsion bars perhaps?
If it broke in half then it was most likely cracked and the load made it flex past the limit point.
I would look very closely at the opposite side as it may be scored and soon to be in a similar state.
If you could provide a picture, it may help to ID the bars in question.
613524
Reply By: Motherhen - Monday, Sep 04, 2017 at 20:54
Contact Hayman Reece, quoting numbers stamped on the bar and hitch. If not too old, they may be able to supply.
613526
Reply By: Member - Rob D (NSW) - Tuesday, Sep 05, 2017 at 18:46
There are 28 inch and 30 inch bars. I have a spare set of 28 inch trunnion bars, not use since I change to 30 inch bars. These are the ones with curved ends that can also be used on the HR dual cam anti-sway system.
613549
