DIY Auto opening camper trailer
Submitted: Thursday, Oct 12, 2017 at 23:31
ThreadID: 135736 Views:5156 Replies:4 FollowUps:4
Looking for advice on installing auto opening for my hard floor camper trailer. Has anyone done this?
Reply By: IvanTheTerrible - Friday, Oct 13, 2017 at 17:13
A couple of linear actuators would do the job
AnswerID: 614313
Reply By: Member - Boobook - Saturday, Oct 14, 2017 at 07:38
Unless the camper was designed to do it, and you know exactly what you are doing, I would say that it will be very unreliable if it works at all.
AnswerID: 614320
Follow Up By: Noeles H2 - Saturday, Oct 14, 2017 at 13:54
Thanks Tony - there are quite a few out there that are factory fitted so I thought an aftermarket one would be doable.
FollowupID: 884910
Reply By: Member - J&A&KK - Sunday, Oct 15, 2017 at 23:50
Are you wishing to have a " press button" auto opening or some form of assisted opening such as gas struts.
AnswerID: 614358
Follow Up By: Noeles H2 - Monday, Oct 16, 2017 at 10:14
Yes, using gas struts. I have seen them on the newer camper trailers which are operated by a switch or remote control. I am not tall or strong enough (a short female) to open it by myself.
FollowupID: 884940
Reply By: Sigmund - Tuesday, Oct 17, 2017 at 12:06
Maybe approach one of the manufacturers that do it and see if they can retrofit to your unit. Eg Pioneer in Melbourne. Speak to Andrew.
AnswerID: 614389
Follow Up By: Member - J&A&KK - Wednesday, Oct 18, 2017 at 13:04
I agree with Sigmund. Installation of appropriate gas struts, that will reduce your effort, to lift the fold out should be able to be done. It will probably require some modifications to your camper to provide strong mounting points for the struts. Good luck with your search for a good installer. Interested to hear the result.
FollowupID: 885015
Follow Up By: Malcom M - Tuesday, Oct 24, 2017 at 07:46
so how do gas struts become 'automatic'?
As already stated you will linear actuators which are a motorised unit so you can have it lower itself as well as open. Struts only open.
Consider how you will operate it all if the linacs, struts or whatever else you decide on fail. Needs a fall back solution.
check out the myswag forums
FollowupID: 885181
