car stereo
Submitted: Saturday, Nov 25, 2017 at 10:45
ThreadID: 135910 Views:3035 Replies:6 FollowUps:1
Has anyone with a 100 series found a good stereo I'm wanting to change mine out and replace it with one that has blue tooth, maps USB, touch screen all the fruit.
Reply By: IvanTheTerrible - Saturday, Nov 25, 2017 at 12:44
A high end DVD unit from a major manufacturer would do the job. Fitted one the other day that was Android based so could run Android apps
AnswerID: 615201
Reply By: RMD - Saturday, Nov 25, 2017 at 16:06
If going to replace it, it has to be removed doesn't it? What then is, "changing it out" if you are simply replacing the device?
Digoptions sell such devices and they are Android system so mapping etc should be all ok. Most have the features you ask for so almost anything will work in it's place. If going for Kenwood and other similar unit you will pay more, but you also have easier recompense/rectification of problems re warranty with a unit from Repco or Motor house.
AnswerID: 615208
Reply By: Member - bbuzz (NSW) - Saturday, Nov 25, 2017 at 18:54
This mob have a good unit with all that you require, including cameras.
Dig Options
bill
Bill B
AnswerID: 615211
Reply By: IvanTheTerrible - Saturday, Nov 25, 2017 at 19:21
Kenwood review
AnswerID: 615213
Reply By: Dean K3 - Sunday, Nov 26, 2017 at 12:02
Biggest problem with touch screen typically double din display unit.
iron oxide dust will collect on screen preventing static conductivity working when you press answer button when phone rings, or user changes menu from radio to moving map etc.
Keeping screen clean is mandatory for both screen/fingers to work and also for user to see maps etc properly.
the dig options aren't bad units I have older unit, and so far apart from teh oxide issue hasn't let me down
AnswerID: 615221
Reply By: Sian - Wednesday, Nov 29, 2017 at 11:03
does anyone know anything about the Zenec and polaris head units
AnswerID: 615269
Follow Up By: IvanTheTerrible - Wednesday, Nov 29, 2017 at 20:26
We used to sell Polaris. Fitted one to a Landcruiser and put Hema on it. Worked great. Polaris has been around for a while an sell in dash GPS and reverse cameras
FollowupID: 886181
