Hilux limp-mode problem fixed
Submitted: Saturday, Dec 02, 2017 at 09:24
Shepbar
To those good folk who offered helpful suggestions, see thread 135839 Nov. 7th, I thank you and I'm pleased to advise the problem part was found and replaced.
An intermittent fault with my 2006 D4D lux saw it going in to limp mode on rough or corrugated tracks.
Turned out it was a worn/faulty accelerator module which is the part attached to the accelerator pedal that sends the drive-by-wire signal;
forum contributor RMD hinted this was the area to check.
Not sure if it's kosher to reveal who the switched-on
Perth mechanic was that I was eventually recommended to and who nailed it, but I'm happy to if allowed.
Thanks again for your help forumites.
Reply By: Bob Y. - Qld - Saturday, Dec 02, 2017 at 09:33
Thanks for getting back to the
forum with the fix.
I suspect your previous thread would be still active, and a similar response there may help people in the future.
I'd give the name of the business, plenty of others do when they've had good service.
615325
Follow Up By: RMD - Saturday, Dec 02, 2017 at 09:56
Bob Y I also endorse telling people who is the switched on mechanic, it is the switched OFF ones people are trying to avoid.
Some aren't completely switched off, just have a high resistance to understanding anything in their field.
886233
Follow Up By: Shepbar - Saturday, Dec 02, 2017 at 10:00
OK Bob, I'm pleased to pass on those details because I've learnt there's a lot more to just having the scanning gear and reading the fault codes; interpretation and experience plays a big part in solving these problems, particularly intermittent ones.
John Dougherty, Port Kennedy Automotive Repairs 08 9524 6777.
Cheers, Shep
886234
Reply By: William P - Saturday, Dec 02, 2017 at 10:54
Why start a new thread? Why not put this in your original thread that is already running so it brings closure to that thread - particularly for those searching this issue at a later date.
615326
Follow Up By: Shepbar - Saturday, Dec 02, 2017 at 12:02
Sorry William, put it down to my
forum inexperience......I've also done as you've suggested after Bob's earlier tip.
Cheers, Shep
886239
Follow Up By: William P - Saturday, Dec 02, 2017 at 13:06
Thanks for that
886241
