Transformer for 12v Oven to 240v...
Submitted: Friday, Dec 29, 2017 at 09:11
ThreadID: 136027 Views:6598 Replies:5 FollowUps:10
I want to set up a transformer to allow me to switch the 12v Travel Buddy oven to be used on 240v when available. Would the following item be suitable, or does anyone have other suggestions (he says... holding his head, awaiting the barrage)?
https://www.ebay.com.au/itm/240V-AC-to-12V-DC-Converter-Transformer-Adapter-Car-Appliance-360W-30A-AU-Plug/122418731002?hash=item1c80b997fa:g:vIoAAOSwZtlaG9ZK
Mark
Reply By: Malcom M - Friday, Dec 29, 2017 at 09:27
Should be fine but a lot of extra work to make it safe to handle plus its somewhat overkill.
However the oven only draws 6-10 amps (depending on the model.)
I'd rather see you buy a supply already in a finger proof case.
Something along the lines of the 10 amp model here-
https://www.ebay.com.au/itm/100-240V-To-12V-1A-2A-3A-5A-10A-Power-Supply-Adapter-Transformer-Charger-New/111548882454?hash=item19f8d4de16:m:mq5PeElxQmqgIOsvat5e3mA
AnswerID: 615759
Follow Up By: Member - silkwood - Friday, Dec 29, 2017 at 09:33
Thanks Malcolm. I looked at these. The unit draws around 10 amps. To create a better connection I could cut the plug off the 12v end and wire into a switch, yes?
I'd like to make this a permanently wired install (the oven manufacturer recommends doing this for the 12v for the oven anyway).
Mark
FollowupID: 886814
Follow Up By: Malcom M - Friday, Dec 29, 2017 at 10:41
Hard to say without seeing what you are doing.
Presumably the 240v is just for caravan parks etc. I'd be leaving the adapter as a separate converter and just plug it it when needed 240v but I don't know how your truck is set up.
FollowupID: 886820
Reply By: Member - kev.h - Friday, Dec 29, 2017 at 10:53
I have a battery charger which also has a dedicated 12v power supply maybe an option with a battery charger thrown in
AnswerID: 615762
Follow Up By: Member - Boobook - Friday, Dec 29, 2017 at 12:41
Wot he said ^^^^^
FollowupID: 886825
Follow Up By: Member - silkwood - Friday, Dec 29, 2017 at 15:17
Didn't think of that.
Cheers.
FollowupID: 886831
Reply By: Allan B (Sunshine Coast) - Friday, Dec 29, 2017 at 11:18
Hi Mark, first missile of the "barrage"...............
The product you instanced does not meet the Australianelectrical safety requirements. It is an offence to offer appliances for sale in Australia that do not meet these requirements.
It is clearly a power supply designed for mounting within computer or similar equipment and from a search I see that it comes from a large batch (1000 plus) of offered surplus manufacturing stock.
That is not to say that it would not serve your needs, but it has obvious safety inadequacies....... The 230v cable is not adequately secured and the 230v terminals are not adequately shielded against personal contact. Further, the 12v 'cigar socket' is certainly not capable of handling the rated 30A output, 10A at most. Even if you purchased this product you would need to attend to these matters.
AnswerID: 615765
Follow Up By: Member - silkwood - Friday, Dec 29, 2017 at 19:01
Thanks Alan, quite obvious that this isn't my area, eh?
Love the word "barrage"! It sounds so dramatic. One of my favourite quotes...
"A relentless barrage of ‘why’s’ is the best way to prepare your mind to pierce the clouded veil of thinking caused by the status quo. "
Probably more than a few on here will recognise it.
Mark
FollowupID: 886842
Follow Up By: Allan B (Sunshine Coast) - Friday, Dec 29, 2017 at 19:13
Don't get me wrong Mark, the product you were interested in would likely serve your needs. But if you use it, be sure to anchor the mains cord over its outer sheath and arrange a well-fixed cover over the terminals..... wouldn't want one of your loved-ones getting electrocuted, would we?
FollowupID: 886843
Reply By: Kazza055 - Friday, Dec 29, 2017 at 13:13
My suggestion would be to get an old power supply from a computer and use that.
Have a look at this article here
I would also advise replace the ciggy plug and socket and using the Anderson connectors especially at 10A.
I run my modem/router and NAS drive from one of these when at home, in the van it just plugs into the 12V battery.
AnswerID: 615770
Follow Up By: Allan B (Sunshine Coast) - Friday, Dec 29, 2017 at 15:17
Well yes, there has been one such on my bench for some time.
But you better have some electrical skill before trying to modify one.
FollowupID: 886832
Follow Up By: Member - silkwood - Friday, Dec 29, 2017 at 15:19
Will definitely be replacing the plug, hate those damn things.
Thanks for that, interesting article.
FollowupID: 886833
Reply By: Life Member - Duncan W (WA) - Friday, Dec 29, 2017 at 15:27
Have you tried a portable car fridge transformer? I have a Waeco fridge that comes with a transformer which is very handy for running a multitude of things that have cig plugs on 240v.
I love my Travel Buddy fridge one of the best purchases I've made for the back of the Troopy!
Dunc
AnswerID: 615773
Follow Up By: Allan B (Sunshine Coast) - Friday, Dec 29, 2017 at 16:11
Hey Dunc, don't put your beer in a "Travel Buddy" fridge. You may be disappointed! lol
FollowupID: 886835
Follow Up By: Life Member - Duncan W (WA) - Friday, Dec 29, 2017 at 20:24
LOL I hadn't noticed I'd typed fridge and not oven. Dherrrrrrrrrrrrrr
Dunc
FollowupID: 886846
