Low pressure stove
Submitted: Saturday, Dec 30, 2017 at 12:13
hooks
Hi all, Can someone please advise if there is a 2 burner stove available on the market. This is one that will fit into the side of a caravan with a bayonet connection. As the vans gas system is low pressure the stove must also be low pressure. It seems these are not generally available apart from the webber products. Most of the RV stores that I have visited don't have anything and the staff are a little vague on this technical issue. Although Companion have one ; part number Comp546 , I wonder if there are any other brands.
Reply By: RMD - Saturday, Dec 30, 2017 at 15:53
Any brand of 2 or more burner stove which runs on direct LPG can be rejetted to make them suitable for use with a caravan regulator and the hose can have a Bayonet fitting added to the hose/cylinder connection.
615788
Follow Up By: hooks - Thursday, Jan 04, 2018 at 11:05
RMD,
To rejet the stove does this mean changing the burners and removing the stove regulator ect. where would you usually obtain the fittings? Most
shop staff even in RV stores are not really up with the details or have an understanding of what to do.
887039
Reply By: HKB Electronics - Saturday, Dec 30, 2017 at 16:37
You could look at marine stoves but they are expensive.
615789
Reply By: Nomadic Navara - Saturday, Dec 30, 2017 at 17:30
Any of these any good to you?
615790
Follow Up By: Member - J&A&KK - Saturday, Dec 30, 2017 at 21:59
The Bromic stoves are of good quality. They also stock the fittings necessary to create a bayonet connection. I have the two burner model in my
Kimberley Karavan outside kitchen. Works fine. I also converted my Weber BabyQ to a bayonet connection, with fittings from Bromic, to allow uniform connectivity with the LPG bottles.
886870
Follow Up By: Member - silkwood - Sunday, Dec 31, 2017 at 10:24
(sorry to hijack your post Bob...)
John, I'm not totally familiar with this myself (most of my experience has been with lightweight, backpack gear- if you ever want to know how to keep a gas stove working in a snow
cave, drop me a line!). What I would love to set up is a stove (most of which I've seen are high pressure- no regulator) and my Baby Q (regulator) on bayonet fittings, possibly to a t-piece from the bottle.
Is it possible to set up the bottle with bayonet fitting (no regulator), have the stove also bayonet fitting (again, no regulator) and the Baby Q with bayonet fitting AFTER the regulator (or am I on completely the wrong track?).
Mark
886898
Follow Up By: Member - J&A&KK - Sunday, Dec 31, 2017 at 12:16
Hi Mark
Sorry but I am not an expert in gas fittings so I can’t answer your question definitively. However I believe a T piece at the gas bottle with bayonet fittings and 2 gas leads , one with a regulator and one without may work.
In my case all the gas appliances for the van have Bromic bayonet fittings. I wanted to use the same gas leads with the Weber so adding the bayonet connector to the Weber was the simple solution.
Cheers John
Weber with Bayonet Fitting
886910
Reply By: Athol W1 - Saturday, Dec 30, 2017 at 21:15
Any stove that is sold with a regulator will do, just remove the regulator and fit a bayonet fitting.
615801
Reply By: Croc099 - Tuesday, Jan 02, 2018 at 20:35
We've been using a Lido Junior for a few years now. It's been great. Love the griller.
Croc
615881
Follow Up By: hooks - Tuesday, Jan 02, 2018 at 20:49
Hi Croc,
Where might I see one of these? Which store or centre would have them.
Thanks Bob
887012
Follow Up By: Banjo (WA) - Wednesday, Jan 03, 2018 at 09:22
Whitworths
Whitworths for one have them.
887018
Reply By: Croc099 - Tuesday, Jan 02, 2018 at 20:58
Hi Bob,
We bought ours at the
camp shop in
Ulladulla. Our high pressure one pooped itself and needed one in an emergency while
camping at
Lake Tabourie. I'm sure other stores would stock them too.
Croc
615882
Reply By: LIFE MEMBER-snailbait - Sunday, Jan 07, 2018 at 10:04
we bought our single burner from BCF they had 2 burner too dont buy a regulater
615943
