Tuesday, Feb 20, 2018 at 14:10
Ivan, Copy & Paste from D-Max website using 4x4 LS-M Crew Cab:
Tare Mass~ (MT/AT) (cab chassis models: final mass depends on body fitted) 1,945/1,945
Gross Vehicle Mass (kg) 2,950
As I stated in my post the Tare Mass for "ute" body is not listed, what is listed is the Cab Chassis Tare Weight, and that does not include the tray. It also does not include
fuel, oil,
water etc. (curb weight). I suspect the Tare weight of a "ute" body will be around 2,300/2,400 kgs. not including fluids.
With a GVM of 2,950 kgs this does not leave much you can load in/on the vehicle, approx. 500 kgs. and this includes the
fuel, oil,
water you have to add. Remember 76 Ltrs of Diesel weighs approx 61 kgs so you have probably got around 70 Kgs of fluids when you include oil &
water. So this brings your load capacity back to 430 kgs. Add to that 350 kgs ball weight if you choose to tow a 3,500 kgs van, you now have 80 kgs left for driver & passengers and their gear. Even using the 2,300 kgs as a tare weight using the same calcs, you only have 180 kgs for driver & passengers and their gear.
Copy & Paste from Prado website using GX Manual:
Approximate kerb weight* (kg) 2240 (includes all fluids)
Gross vehicle mass * (kg) 2990
This means you have 750 Kgs that can legally be loaded into the vehicle. 300 kgs ball weight for a 3,000 kgs van comes back to 450 kgs for driver & passengers and their gear.
D-Max has a 76 Ltr.
fuel tank, Prado 150 Ltr combined.
888532
