scangauge setup
Submitted: Thursday, Mar 22, 2018 at 18:39
lance m1
do we have a member here in
townsville who has a scangauge11 who can assist setting a ford
ranger 2017 up for a fellow traveller for a carton regards lasue
Reply By: Dean K3 - Thursday, Mar 22, 2018 at 20:44
Installation easy as:
find OB2 port location varies but under dash near right knee area be good starting point.
find a safe route for cable between OB2 connector and head unit to run cable then connect up with no power unti will then detect the engine parameters when you turn on igniton.
user installation guide is fairly comprehensive - apart from possibly the
tank to empty set up procedure - this require bit of playign around with, and to keep it in sync you must remember to reset the trip zero (refill) each time
The extra codes are fairly simple to program in so long as your confident -admit I had to think back to my days of Hex coding to get it right 0 to F = 0 to 16 in hexadecimal
617768
Follow Up By: Zippo - Friday, Mar 23, 2018 at 00:16
0 to F = 0 to 15 actually.
889555
Follow Up By: Hewy54 - Friday, Mar 23, 2018 at 06:23
0123456789ABCDEF
16 characters by my counting
I found set up to be very easy.
Scangauge provide a quick start up and a more comprehensive guide.
Both are easy to follow.
889557
Follow Up By: Genny - Friday, Mar 23, 2018 at 09:07
.. and yet Zippo is right.
F = 15.
0 to 15 is 16 characters
889560
Follow Up By: Member - McLaren3030 - Monday, Mar 26, 2018 at 20:58
Hi Guys, I am confused here.
0 -> 9 = 10
ABCDEF = 6
10 + 6 = 16 ???
Macca
889666
Follow Up By: Hewy54 - Monday, Mar 26, 2018 at 21:15
No confusion really.
The original post was correct.
It is a hexadecimal system with 16 characters.
Did not think it was worth arguing with anyone who cannot count to 16.
889667
Follow Up By: Zippo - Tuesday, Mar 27, 2018 at 00:00
You're right Macca, there ARE sixteen. But 1 to 16 would be 16 (just like 1 to 10) and when you start with zero (as in 0 to 9, there are ten) then 0-F is 0-15.
After 0-9 it goes A=10, B=11,C=12,D=13,E=14, and F=15.
Hewy, I can count to 16 and "0 to F = 0 to 16 in hexadecimal" is wrong. If you knew hex coding you'd know that F is 15.
889673
Reply By: glids - Friday, Mar 23, 2018 at 16:49
I don't know how hard setup is for the Ford
Ranger.
Some years ago I had a Terracan, and it was a PITA to set up - needed to select ISO mode and 'Force' it. Even then it wouldn't always connect.
If you have problems setting it up using the guide, I suggest asking your question on a Ford
Ranger Forum - there will be plenty of replies. Alternatively, send off a query to Scangauge Australia.
good luck,
glids
617791
Follow Up By: lance m1 - Friday, Mar 23, 2018 at 17:45
glids thanks for the reply starting to work out now i have temp code regards lasue
889568
