Monday, Apr 09, 2018 at 13:45
WHATS IT WEIGH?
There have been a number of articles lately about the weight of vehicles, loaded up for touring. We have travelled the Middle East and African deserts and Australian Outback and are very cognizant of weight as a negative in off road travel. Every day I see articles for more “must have goodies”. We travel very lightly carrying only what we consider prudent. There a number of off-road manuals on
what to take and how to handle potential problems: Sadly, many of the better ones are out of print. They had much practical advice -- What is useful and how to prepare a vehicle for severe travel where there will not be any help coming, etc. I reviewed our vehicles and some others that are similar to gauge what people add on, carry or suggest and why with particular attention to weighs. The following is a listing of things I could identify, in kilograms above tare weight. Most are actual measured weights, some from catalogues or an estimate of the difference between the OEM and “upgraded” equipment. I have listed items as single pieces, so if more than one similar item is carried; shackles for instance, multiply the item weight appropriately. This list is based on two people travelling for 4-6 weeks will minimum top-ups for food. Our experience is that for each additional person the food, bedding, shelter, and clothing requirements increase by 50%. Certainly, this list is not complete, but hopefully will provide a starting point for evaluating your equipment needs and gear weights. The objective of keeping weight down is countered by the need to be able to address incidents on the track. Remember, “Vehicle
tools and parts stay with the vehicle; they do not go in the house.”
Fuel at 0.8 per L; Bull Bar,10.0; Rear bumper (with wheel carrier),15.0; Second spare tire/rim, 40.0; Front recovery points, 5.0; Roof Rack (Aluminum),35.0; Roof Top Tent,50.0; Interior Roof Rack,8.0; Bed Slide/Drawers,50.0; Awning,28.0; 12,000 Lb winch + Dyneema Rope,20.0; 12,000 Lb winch + Steel Cable,32.0; small LED front light bar,0.2; Oven 12 Volt Marine,1.5; UHF radios,0.2; Battery Isolator [VSR],nil; LiFePO4 Battery-100 A/Hr,13.0; 2nd Lead battery (Deep Cycle),25.0; DCDC Charger,0.2; 500 W inverter, 0.1; Solar Panel 160W/Controller,16.5 ; Air Compressor and
tank,9.0;
Water pump, 1.2; 90 L Frig/Freezer,30.0; 40 L Frig/ Freezer,17.0; 10 L Frig/Freezer,5.0;
Water tanks 40 L,40.0; Sand Ladders – 4,12.0;
First Aid Kit (extensive),5.5; PLB, nil; LPG
Tank – 3.5 Kg capacity,5.0; Combination wrench set,1.0; Socket Set (1/2” drive),4.9; Small tools,0.2; Hose splicers and clamps,0.2; Jumper Cables (HD),3.6; Motor oil 1L, 0.8; Fluids-Brake/Steering, 1.0; upgraded size tire from OEM, 5.0;Tire Bars,2.6; Air Hose/Gauge,1.5; Sledge Hammer,1.2; Bow Saw,0.1; Fan Belt (set),0.2;
Fuel Filters (set),0.6; Radiator Sealant, nil; Fuses/bulbs, nil; Wheel Nuts/Studs+ Misc Bolts,0.8;Tire Tube +Talcum Powder,1.75; Tire Repair Kit,0.85; 2T Hydraulic Jack + 2 extensions,4.5; 2T Mechanical Jack,4.0; Hi-Lift Jack, 14.0; Shovels (long handle and folding),3.04; Snatch Strap,3.05; Load Spreader Strap,0.4; Tree Strap,1.3; Tow strap,2.9; Dyneema Shackle,0.1; Steel D-Shackle, 1.3; Ultra light aluminum snatch block, 0.7; Std. Steel snatch block, 3.0; Line restraint,0.25; Jack Pad,0.1; 2 average persons (F60/M85), 145.0; Frozen Food,50.0; Emergency Food,20.0; Snacks/Drinks,~10.0; Cooking/Eating utensils,10.0; Clothes/Toiletries for two,30.0; Communications/Navigation,0.2; Chairs/Tables for two, 10.0; Bedding, 1.0; Tent Stakes – 6 plastic, 0.2; Storage Box, 4.0; Tow Bar, 25.0; Chainsaw and supplies, 11.0; All the nils added up, 2.0.
618171
Follow Up By: Member - Bigfish - Monday, Apr 09, 2018 at 16:52
Bullbar at 10kg? Steel are around 80kg and alloy 35kg.
890091
Follow Up By: Ron N - Tuesday, Apr 10, 2018 at 14:03
A bullbar that only weighs 10kgs wouldn't cope with a poddy calf! LOL
A lot of those weight figures are highly variable, and travellers are best advised to make up a list of "essentials" - then pare those essentials down to only that which is really needed.
I wouldn't mind a dollar for every unnecessary kilo, and unnecessary item, dragged thousands of kms around Australia, and through the Outback by travellers!
I can remember some friends loading up their HJ75 Landcruiser traytop for a trip up the CSR in 1989, and after loading up the 'Cruiser with every "necessity" - and it started to buckle at the knees - they decided to weigh it. It came in at over 3200kgs!
After that shock, there was a lot of soul-searching as to what was defined as a "necessity"!
Cheers, Ron.
890119
Follow Up By: Member - peter_mcc - Tuesday, Apr 10, 2018 at 14:16
10kgs extra for the bar? You sometimes take bits off to fit a bullbar. My steel AFN bar on the Prado doesn't weigh 80kgs. No idea how it would go with a poddy calf but it's ok with kangaroos...
890122
Follow Up By: Member - silkwood - Tuesday, Apr 10, 2018 at 14:18
"I wouldn't mind a dollar for every unnecessary kilo, and unnecessary item, dragged thousands of kms around Australia, "
My point exactly, but she insists on coming along!
890123
Follow Up By: Ron N - Tuesday, Apr 10, 2018 at 14:36
Peter - Most of the items you have to take off to fit a bullbar, hardly weigh anything! - they're all plastic!
Unless you happen to have a truck - and even then, they're currently all plastic, resin and fibreglass materials, and as light as they can make them.
It's been a few decades since I last saw a steel bumper as original fit!
I grabbed a 79 series Cruiser plastic bumper that was sitting in a big box of surplus bullbar-fitment items, at an auction house yesterday, and I was surprised at how light it was.
Cheers, Ron.
890125
Follow Up By: Member - peter_mcc - Tuesday, Apr 10, 2018 at 14:45
My Prado had a big steel beam behind the bumper that got removed. The bumper itself, whilst plastic, probably weighed another 10-15kgs. Hardly nothing...
890126
Follow Up By: Ron N - Tuesday, Apr 10, 2018 at 15:19
Peter - the Toyota EPC tells me the "Reinforcement Sub-Assy, Front Bumper" (often called the impact beam) for the Prado only weighs 5.8kgs.
There's not much metal in them - I just pulled the rear one off the missus' 2012 Camry, to fit a towbar.
There is also a polystyrene foam "Absorber, Front Bumper Energy" (P/No 5261112190) behind the Prado bumper which weighs 0.11kgs - plus two reinforcements, "Extension, Sub-Assy, Front Bumper" (P/No 5202660011), at 1.1kgs each, making another 2.2kgs.
The Prado plastic bumper itself only weighs 4.5kgs, but it goes to 9kgs if it's the fancy bumper model with chrome additions.
There's also a range of plastic and steel brackets holding all the original Prado bumper arrangement on, none of which would make up any more than a kilo in total weight.
All up, it only just lightens the Prado by a bit over 10kgs when you pull everything off the front to fit a bullbar.
Cheers, Ron.
890127
Follow Up By: Member - peter_mcc - Tuesday, Apr 10, 2018 at 16:01
I need to go to the gym more... I could have sworn they were heavier than that.
890130
Follow Up By: Member - abqaiq - Sunday, Apr 15, 2018 at 08:06
Note I mentioned: OEM and “upgraded” equipment. The weights for say a bullbar are for the upgraded ARB type over the Toyota standard for a 78. So the 10 is additional to standard. The weights are either estimated when I couldn't take the stuff off or more usually actual for things that are loose. This listing just shows how fast weight piles up!
890234
Follow Up By: Member - Boobook - Sunday, Apr 15, 2018 at 08:48
The front impact bar that comes standard on the Toyota is a rectangular hollow aluminium bar to spread the impact force.It wouldn't weigh much more than a few kgs.
890235
