Putting in waypoints
Submitted: Friday, Apr 27, 2018 at 20:16
Member - David L1 (VIC)
I have a list of
places to visit but they are recorded in degrees minutes seconds. Does anyone know how you can input them into
ExplorOz Traveller please.
Reply By: Member - ACD 1 - Friday, Apr 27, 2018 at 22:06
David
You will need to convert them to the appropriate format.
I can give you the mathematical equations you will need to do this, however you might find this
Coordinate converter easier to use LOL. (Just click on the underlined words and it takes you to an ExplorOz page)
Cheer
Anthony
618567
Follow Up By: Member - David M (SA) - Saturday, Apr 28, 2018 at 10:41
Can't you put the degrees into a GPS and then change the GPS format to that required.
Dave.
890585
Reply By: Member - J&A&KK - Saturday, Apr 28, 2018 at 10:03
David
The method to convert DD MM SS formats to DD.DDDD formats is straightforward. So if you prefer to do it yourself in excel or via calculator use the following method (with example -32 15’ 28”)
A. Divide SS by 60 ( 0.4667)
B. Add the result of A to MM (15.4667)
C. Divide the result of B by 60 (0.2578)
D. Add the result to DD (-32.2578)
Cheers John
618571
Follow Up By: Member - Boobook - Saturday, Apr 28, 2018 at 16:48
In your example you would subtract the result of C from DD.
Its easy to use one of many online calculators,some allow waypoints or csv files to be loaded too.
890595
Follow Up By: Member - J&A&KK - Saturday, Apr 28, 2018 at 20:39
Tony
You are correct. Should be a minus not a plus. Was thinking of a South delimiter not minus.
Cheers John
890599
Reply By: hooks - Saturday, Apr 28, 2018 at 18:48
David, are you using a hand held GPS or some other type? If its a hand held what brand and model is it?
Bob.
618585
Reply By: Craig M1 - Sunday, Apr 29, 2018 at 11:00
Hi David
I thought may be there is a setting in "Traveller" whereby you can select whether you want to input in degrees, minutes, seconds or decimals of minutes. There is in most other navigation packages.
Cheers Craig
618600
Follow Up By: Member - Rod N (QLD) - Sunday, Apr 29, 2018 at 11:37
You can change the format for the map but for some reason the input box format remains at decimal degrees. Contact with David/Michelle may be the go?
890615
