Thursday, Jun 07, 2018 at 00:33
Travelled the traditional track direction (North to South) and had to exit at
well 33 due to the bottom
track closed (flooding). The only issues we had were with an Oka heading north running 38psi (admitted) which chewed the track to bits. Heard him attempting to climb one
sand dune and after about 15 mins he appeared on the top. Spoke to him about tyre pressure and he blamed v8 landcruisers for chewing up the track.
Then we had a group with trailers snatching themselves over a heap of dunes.
We had no trouble and used low range on three
sand dunes due to the chewed up track to the top. For those interested our average speed was about half that in track notes and we ran 10psi front, 15psi rear and 10psi camper.
Fuel consumption in the MY16 (200 series with DPF) was 30 (and a bit) per 100kms.
Diesel at Billiluna $2.90,
Mulan $2.20 and
well 33 roadhouse $3.40. Punmu was $2.50 (cash) or $3.00 (card).
The corrugations were worst between wells 35 to 33.
One of the wells was unusable due to a chemical potty being emptied into it.
Rangers station checking permits at
well 49 and it was the best
water other than
well 33 which had green grass.
Ran into two blokes with a camel train (5 camels) and the info is on greatsandy18.com. One of the riders was the great grandson of
Warburton and they were following the original 1870 track notes. Also ran into a trackcare team who were installing duel
toilets and restoration of wells.
I believe the CSR is still crown land and the property owners land is on either side of the allocated crown land so I am not sure if the so called trailer ban is enforceable or legal. We respected this in any case. Rangers told us that the property owners (wells 1 to 4) changed hands but we did not make any inquiries if the signed 'no trailers' is still the wishes of the property owner.
619399
Follow Up By: Frank P (NSW) - Thursday, Jun 07, 2018 at 11:04
"One of the wells was unusable due to a chemical potty being emptied into it."
I cannot believe that a human being could be so ignorant/dumb/stupid/callous. I guess they are not really human beings, more sub-human, if they've evolved that far. Should be strangled at birth.
891685
Follow Up By: Gramps - Thursday, Jun 07, 2018 at 12:03
Prime candidate for retrospective abortion.
891687
Follow Up By: Lloyd M1 - Thursday, Jun 14, 2018 at 17:31
Is it better to tow a trailer to spread the weight or travel in an overloaded vehicle when doing the CSR
891841
