Hilux question
Submitted: Friday, May 11, 2018 at 20:52
ThreadID: 136686 Views:3784 Replies:2 FollowUps:1
A friend has a 4yo Hilux twin cab ute. In the tub on the front wall are two holes covered by metal covers secured by two phillips head screws which are on the outside of the tub between the tub and the rear of the cab. These two holes are leaking water into the tub. Does anyone know what these holes are for, are they known to leak, what is the best way to seal them?
Reply By: qldcamper - Saturday, May 12, 2018 at 08:33
I have a similar model and know the plates you speak of, I have looked at using them but its impossible to get them off without taking the tub off, I have not noticed if they leak or not.
How does he get water in from them? is it from driving through deep water of from rain and washing?
Only way I could think of to seal them would be to give them a good clean with turps from the tub side and wiping silicone into the seam then cleaning the excess off with more turps.
AnswerID: 618831
Follow Up By: Mikee5 - Saturday, May 12, 2018 at 13:20
When it rains water enters from between the tub and the rear of the cab. Three hours labour to r&r the tub from his local Toyota dealer.
FollowupID: 890946
Reply By: Matthew G3 - Saturday, May 12, 2018 at 10:16
Hi Mikee5
I don't have one but some utes have the holes there to let air flow under the tub liner if you have one in. With no tub liner they come with plates on the holes, if these are the one in question.
Matt
AnswerID: 618837
