Wednesday, Aug 01, 2018 at 10:27
LOL left hand and right hand of the Government :)
Desert Parks Bulletin
No. 595 – 27 July 2018
On-line
park bookings commenced 1 June 2017. See end of Bulletin for details.
Simpson Desert – Open to 4WD. Caution at erosion and corrugated areas.
Please ensure 4WD is engaged and that you reduce tyre pressures while in
the desert to minimise cutting up the tracks. Use extra caution as
sand dunes will be soft after the summer closure, and may have blow outs from summer winds.
Carry extra
fuel reserves as up to 50% more
fuel may be used currently than a normal desert crossing.
The use of trailers in the
Simpson Desert is strongly discouraged. Caravans and motorhomes should not be used. Serious damage can be caused to vehicles and the environment, and difficulties are likely to result.
Warburton Crossing – Closed due to flooding."
I wonder what would happen if you were to be on it given the letter you have???
Apparently it has been used by some of the locals so there really isn't much in it
892881
