Oh crap
Submitted: Monday, Sep 10, 2018 at 18:36
MUZBRY- Life member(Vic)
Gday
My little darlings gave me a Thunder Box for fathers day , i was thinking i can use that.
Well my little darling took me up to the
Avon River last weekend which gave me plenty of time to test the Thunde box
. After setting the box up in a spot that had a nice view, i settled down to give it a good test. What a plesant way to spend time in the bush, the Thunder Box was just great and i recomend them to all and sundry.
Reply By: IvanTheTerrible - Monday, Sep 10, 2018 at 18:43
Been using one for over 5 years. Only downside we have found is it can and will sink in sandy areas
621134
Follow Up By: Member - McLaren3030 - Monday, Sep 10, 2018 at 19:33
Also make sure you don’t dig the hole too wide, that’ll make it sink for sure.
893667
Follow Up By: IvanTheTerrible - Monday, Sep 10, 2018 at 20:14
I have pop riveted two bits of 30mm RHS on the bottom of the two non folding sides and put two half meter bits of pipe through them when on soft ground
893668
Follow Up By: Shaker - Monday, Sep 10, 2018 at 21:43
I made a cut out base with a routed slot the same as under the top, put 2 swivel catches on it the same as under the top. It all still fits in the same bag.
If you don’t have router skills, you could just nail a light batten on to a cut out base so that it locates around the inside of the box.
893669
Reply By: RMD - Tuesday, Sep 11, 2018 at 14:06
Is it any good in the middle of a rice field to scare the ducks away?
621146
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Sep 11, 2018 at 16:48
Depends on what you have been eating!
893677
Reply By: OutBack Wanderers - Wednesday, Sep 12, 2018 at 23:02
That was quick, after reading the whole post, I just bought one for $119.00 plus free delivery, win win
621175
Reply By: Member - Boobook - Thursday, Sep 13, 2018 at 09:31
I had one for a while,. No doubt they are a great way to do your duty.
Not so nice when you pack it up and put it in the back of a wagon
621181
Follow Up By: Shaker - Thursday, Sep 13, 2018 at 21:05
I can’t see why it would be a problem, unless you are using it incorrectly.
893721
