Jackaroo Diesel Service the injector high pressure rail fuel filter (very fine m
Submitted: Tuesday, Jun 15, 2004 at 02:51
DCoop
Daryl suggested to a previous caller that to fix a problem, By Servicing the injector high pressure rail
fuel filter (very fine micron ).
Could someone please tell where I can find this filter ?
DCoop (Dennis)
Reply By: The Banjo - Tuesday, Jun 15, 2004 at 08:39
You may speak of the small filter down low on the passenger's side of the engine. That one screws off upwards....little tricky to get to - clean the area quite
well first - you must not have dirt enter the flange area. Non genuine is Ryco Z79a - the genuine is not too pricey but. Manufacturer specifies this filter as not-for-replacement until the engine is overhauled....'phooey' says my mechanic- 'if its cheap, change that too' ! (I do
mine each 10,000k).
63193
Follow Up By: Dion - Tuesday, Jun 15, 2004 at 09:40
I also find removal of the heat shield around the
fuel filter makes for easier access as
Dion.
324494
Dion.
324495
