colorado 7 horn
Submitted: Sunday, Feb 24, 2019 at 16:19
nick j3
hi, I have a 2013 Colorado 7, and would like to replace the horn with something a bit beafier, but im having reouble trying to locate where it is,
Reply By: Athol W1 - Sunday, Feb 24, 2019 at 17:29
Nick
Have you removed the plastic panel forward of the radiator, if the same as the Dmax then it is just below that panel on the left side of the vehicle.
Athol
624070
Reply By: nick j3 - Sunday, Feb 24, 2019 at 17:37
cheers mate, I can just see it under there, I need to get some star allen keys to take some of the little screws out
624071
Follow Up By: RMD - Sunday, Feb 24, 2019 at 19:42
Star Allen keys are Torx heads. So Torx bits are what you are looking for.
Be careful with the current load if changing the hooter. The Holden product will have an electrical system already working to the max. You may need to add a switched relay operated by the OE hooter terminals to operate the relay if it draws much more than the original one.
897472
Reply By: nick j3 - Monday, Feb 25, 2019 at 21:35
turns out theres 3 of the damn things 2 near the radiator and one near the firewall
624091
Follow Up By: RMD - Monday, Feb 25, 2019 at 22:40
Are you sure they are all horn related????
Maybe the on enear the firewall is a security/alarm related device. Try the horn and listen IF all 3 operate at once or that one is mute.
897496
