Friday, Mar 01, 2019 at 11:43
thinkin
You said,
"I'm familiar with
United Injection but I think there more into pre common rail ECU".
In
Perth you might have a place called
United injection but it read differently to me.
If you meant THEY ARE more into pre common rail stuff then the "there" means over there which I read as there is other types of injection. The're means something different. So I mentioned the various types of injection concepts, whereas, you are talking about their business. Funny how a word can change the meaning isn't it?
If using the BT50 around suburbs I would expect that to be relatively normal
fuel usage, depending on the stop start frequency involved and accellerating with traffic. If you notice smoke from the exhaust you have to be pressing more than is actually needed to speed up. ANY smoke out a diesel exhaust is $$$$$ for no benefit. If accellerating slower and more progressive, you then aren't asking the ECU to deliver a larger than required squirt of
fuel, the turbo will speed up and match the
fuel input and you will hardly get any smoke, negligible amount and a $$$$$ saving too. Most people flop the throttle open and back off when they feel some action, worst way to do it!
Start slow and the system will bring up turbo revs and boost level THEN it has the ability to burn more efficiently without wastage/smoke and you can bury the pedal when ON boost and it should compensate with hardly any smoke at all. Everything which happens before boost is fully operational cost $$$$$. Unfortunately it is difficult to train drivers to conciously do this.
If you have bigger rims / larger OD tyres or wider tyres that too will add to
fuel costs.
897542
