TLC gearbox info
Submitted: Friday, Jun 18, 2004 at 14:51
ThreadID: 13892 Views:2034 Replies:2 FollowUps:0
Hello
I'm Rajeeb Patnaik from Bhubaneswar Orissa India.I have a 72 TLC FJ40.I swapped the petrol engine and ploncked in a Toyota 13B diesel retaining the original 3 speed gearbox.Facing serious problem with lugging in first gear.I need a lower ratio first gear wid adequate lower ratio transfer case.Please suggest a suitable four speeder cos I'm satisfied with the 1:1 ratio top gear and 3.71 final drive ratio.
Rajeeb Patnaik
+91 674 2002289
Reply By: biscuits - Friday, Jun 18, 2004 at 17:01
Take a look at:
http://www.marks4wd.com/lc-bj40-info.htm
http://www.marks4wd.com/lc-fj40-info.htm
It might help you find a more suitable 4 speed for a conversion.
Dave.
AnswerID: 63784
Reply By: Member - DOZER- Saturday, Jun 19, 2004 at 13:20
best option is to look for a preloved 4 speed from a 3b with the later style(80 and later) transfer (that is alot stronger) and put the lot in. These 40's had something like 4 different 4 speeds for the different diff ratios.
Good luck
Andrew
AnswerID: 63916
