Coil sprung patrol GVM upgrade?
Submitted: Sunday, Nov 24, 2019 at 07:10
ThreadID: 139351 Views:7973 Replies:4 FollowUps:3
Hi all,
I'm interested in purchasing a patrol station wagon (2008 model) and was curious if anyone knew of a GVM upgrade available for this model?
I know there is one available for the rear-leaf models.
Reply By: mechpete - Sunday, Nov 24, 2019 at 09:05
think you will find it difficult , a mate of mine had his coil cab ute done a month ago
an found not many are keen on coil spring upgrades .his was done in Shepparton
cheers mechpete
AnswerID: 628772
Reply By: Member - John - Sunday, Nov 24, 2019 at 09:48
Yes, my 4.8 was done a few months ago, ATOC in Lilydale Melbourne. Many other firms do the wagon also, google will be your friend.
John and Jan
AnswerID: 628774
Reply By: mountainman - Sunday, Nov 24, 2019 at 20:27
Keep an eye on the coil spring retainer mounts on the chassis
They are known to crack on the patrols in the rear when frequently driven with a decent load on.
There are bracing kits you can buy on the market from superior engineering or similar companies
AnswerID: 628783
Follow Up By: Member - John - Monday, Nov 25, 2019 at 06:25
Mountainman, is part of the GVM upgrade, has to be the welded type, not the bolt on type.
John and Jan
FollowupID: 903337
Follow Up By: Member - Vince M (NSW) - Monday, Nov 25, 2019 at 07:55
John is spot on
There are several ways & there is also a kit to beef up the chassis all have to be welded on
It was common to get the cracking
FollowupID: 903338
Follow Up By: Member - John - Monday, Nov 25, 2019 at 08:33
My dual cab chassis belt and braces, ATOC welded in coil tower brace, lower circled bit, CSE coil tower brace, upper circled bit, PSR chassis fishplates welded along chassis rails also.
John and Jan
FollowupID: 903340
Reply By: sweetnam - Thursday, Nov 28, 2019 at 13:02
With the weld on brace i believe the new limit is 3540kg based on the axle load ratings.....
AnswerID: 628829
