8 inch tablet suggestions
Submitted: Tuesday, Jan 21, 2020 at 18:47
ThreadID: 139576 Views:40232 Replies:14 FollowUps:18
Gday - I'm thinking of going to 8 inch tablet to replace HN7 for my next trip away.
(10 inch seems too big)
It will require 4G, GPS and a good daylight screen; and be able to handle ExplorOz Traveller, Wiki and other apps. Etc.
Any suggestions?
Trevor&Verna, Kal WA
Reply By: Kazza055 - Tuesday, Jan 21, 2020 at 19:04
I was going to buy one of the Lenovo Tab E8 8" 16GB Wi-Fi - Slate Black to use as a navigator for an upcoming USA road trip. My wife put her foot down and made me buy a Samsung Galaxy Tab A 10.1" 32GB - Black so who was I to argue ;=))
In hind sight it was a good move as it is great to use. Only problem I can see is that I will not be able to leave it in the car while sightseeing.
AnswerID: 629623
Follow Up By: Member - Boobook - Tuesday, Jan 21, 2020 at 19:28
Your wife is smart. I had a couple of Lenovo's. They were unreliable and support was hoplessly slow. They never fixed the issues with the touch screen.
I agree Samsung.
FollowupID: 904660
Reply By: terryt - Tuesday, Jan 21, 2020 at 19:05
Lenovo, Samsung etc all pretty good. I have a Lenovo which does not take a sim card {ie no 4g) However it does everything you want except for calls and the very rare times I need internet on it I hotspot with my phone. I think all the screens are pretty sensitive to glare. Either put it down low away from glare or as I do, use a hat to keep the glare off the screen. Works a treat. PS you can get a Lenovo that takes a sim card but they are a little more expensive (still cheaper than Samsung)
AnswerID: 629624
Reply By: Member - wicket - Tuesday, Jan 21, 2020 at 20:06
You haven’t mentioned how much you are willing to spend, so I’m assuming money is not an issue :) that being the case I would go with the ipad mini cellular , will do all you want and it has plenty of memory for all you maps etc.
AnswerID: 629625
Reply By: Member - Warren H - Tuesday, Jan 21, 2020 at 22:35
Lenovo E8 16GB ~$110 wifi only ~$200 4G vers
128GBmicro SD card $40. So if you hot spot your phone you could set your self up with ExplorOz Traveller with maps for $250. All Android tablets come with a GPS BTW. My wifi only set up worked fine. Not great in direct sun but floor mounted with RAM mount finding an angle wasn't difficult.
NT Pajero
2007 Goldstream Crown
AnswerID: 629628
Follow Up By: Member - Boobook - Wednesday, Jan 22, 2020 at 03:34
Be careful. Not all Android tablets come with a GPS. In fact most under $100 Don't.
FollowupID: 904670
Follow Up By: Member - 2208mate - Wednesday, Jan 22, 2020 at 08:36
Somebody here recommended the Lenovo E8 16Gb a couple of months ago, I bought one only for the Exoz app and it was $110 delivered
It's been a good buy so far and has been through a couple of deserts(and the grand kids have fiddled with it extensively). Seems robust enough for medium work and for tough work whatever cover you buy may mean the difference. The concept of the 8 inch pad is good from the ease of handling while mapping in the scrub, if you intend mounting it definitely get the 10 inch.
It's not my only source of navigation, but if it was, I think it would a lot harder to make a purchasing decision as to what was bullet proof or not.
FollowupID: 904673
Follow Up By: nickb - Thursday, Jan 23, 2020 at 02:12
I have a 7” Lenovo tablet running hema maps. It is quite laggy which can be very frustrating. When I turn the car off and later start it again, the gps goes bananas and the track log starts flying all over the screen. As above doesn’t handle the heat too well either. For $99 you can’t expect perfection I suppose!!!
FollowupID: 904678
Reply By: Member - Vince M (NSW) - Wednesday, Jan 22, 2020 at 09:25
Trevor & Verna
I had the Hema 7 & the later glass one both gave nothing but problems over heat, pad out of sync etc. etc. had them back & fourth many times in warranty & out of warranty.
So I went an IPad 10.5 pro & has been great not one problem & I use it as laptop, camera etc. as well, Yes on a cruiser/patrol etc. it would be too big I would think, mine is on a dash mount on my Isuzu NPS 300 4x4 truck/camper (big windscreen) it has never over heated or missed a beat so you may want to think of one of the smaller units, they will run most navigation packages
Good luck
AnswerID: 629632
Reply By: HKB Electronics - Wednesday, Jan 22, 2020 at 10:00
Have a Samsung, excellent unit.
One thing though the Explore app uses a lot of power so you will need to have the tablet constantly powered if using as a GPS.
AnswerID: 629633
Follow Up By: Frank P (NSW) - Wednesday, Jan 22, 2020 at 10:50
Agree, and use a Samsung ciggy adapter or one made to Samsung specs to ensure max rate charging. Slow charging from other adapters will charge ok when not in use, but will not keep up with GPS + Traveller + OziExplorer.
FollowupID: 904674
Follow Up By: Life Member - Duncan W (WA) - Wednesday, Jan 22, 2020 at 19:48
Totally agree about the power consumption using the cig plugs usb's even on 2amp my Samsung just sucks power. In the end I have it plugged into my 100w Waeco inverter and no problems.
Dunc
FollowupID: 904676
Follow Up By: Bob Y. - Qld - Thursday, Jan 23, 2020 at 06:50
I've often had this problem, with Hema maps on an old iPad.
Going up the Canning last Aug, the iPad was beginning to throw a tanty, so plugged it into an item I'd bought from RTM/Jaycar. 4 of USB outlets, 2 on a 2M lead obviously for running tablets in a sedan, wagon etc. Output is 2.4A per USB and that little extra had the iPad behaving again.
FollowupID: 904679
Reply By: Frank P (NSW) - Wednesday, Jan 22, 2020 at 10:41
There are plenty of suggestions re brands, but on size, if you're running some detailed maps you may find the 7 inch screen a bit small. I certainly did.
I have had great success with a Samsung 9.7 inch tablet. I can run EO Traveller and OziExplorer simultaneously, either switching between them (full scsreen) or displaying both simultaneously in split screen mode.
It also doubles as a reasonable camera for Places pics (can upload straight from the device rather than transferring from other devices/cameras) , internet, email, etc.
AnswerID: 629634
Reply By: Member - pedro1 - Wednesday, Jan 22, 2020 at 12:52
For my needs I required a cheap Chinese unit running Windows CE so I could use Oziexplorer with maps I had gathered over the years. I also needed a reversing camera input . I found not many suited the bill.
I ended up with one from digOptions for $160
7"HD 4x4 GPS OziExplorer 4WD Australian Maps
Portable GPS Nav Bundled with comprehensive street & off road maps. The included Off Road Map Data has plenty of info on most 4X4 tracks right across Australia. Simple and Intuitive Touch Screen Menu. with an 8GB flash internal memory with Street Maps.
https://www.digoptions.com.au/7-hd-4x4-gps-oziexplorer-4wd-australian-maps-topog
It was out of stock when I ordered it but came in stock a couple of weeks later
AnswerID: 629635
Follow Up By: Life Member - Duncan W (WA) - Wednesday, Jan 22, 2020 at 19:52
Pedro based on the unit specs that sounds like an excellent buy.
Dunc
FollowupID: 904677
Reply By: Mick O - Wednesday, Jan 22, 2020 at 20:50
Trev, I'm a Samsung convert and am running a Galaxy Tab 8A as well as the 10"S3 unit. I have the Samsung Note 9 for a phone. I am running Oziexplorer for Android on them all and they have performed faultlessly across a wide range of travels. Even smashed the 8 in the door up at the cape. Worked well enough despite a shattered screen. Simply replaced that when I got back home.
These units have been strapped to the front of the quad on several expeditions now and are generally mounted up front in the Tojo. I'd recommend getting a solid external case for them. There are plenty of sub-$30 ones on ebay or spend up to $90 on an Otterbox or something similar.
Good performance on wifi and excellent on the GPS for those times you'r off the beaten track. Camera's are good quality. Good voice recognition programs for taking notes and journals as well. Saves typing. Also use it for engine diagnosis (Bluetooth) through Torque App and of course it is set to control GoPro cameras and the DJI drones.
Very reasonably priced as well (compared to some fruit derived products) particularly during a sale at Officeworks, JB hifi or similar.
Mick
AnswerID: 629637
Reply By: IvanTheTerrible - Wednesday, Jan 22, 2020 at 20:55
Samsung Tab8 here. Use it for work and for navigation. Have tried using cheap units but the lag is rediculous
AnswerID: 629638
Reply By: Member - Lyncol - Wednesday, Jan 22, 2020 at 21:04
Trevor & Verna
We use an 9.5" ipad with hema maps loaded and have 4G and GPS. We use to have it sitting on the dash, but found that too hot for it. We now attach it with a 3M product - Duralock- to the front of the radio, because we don't use it on our trips. We have travelled some very rough roads and it hasn't come off yet.
I have attached a couple of photos.
AnswerID: 629639
Follow Up By: ExplorOz Team - Michelle - Thursday, Jan 23, 2020 at 14:25
I'm sure the 3M product works fine, but these days for $30 you can pick up the Scosche magnetic mounts from JBHifi. We have a couple of them and can vouch for their incredible magnetic strength to withstands the toughest 4WD conditions. We have phones, tablets, and reversing camera screens mounted - so versatile!
Michelle Martin
Marketing & Customer Support
FollowupID: 904685
Follow Up By: Member - McLaren3030 - Friday, Jan 24, 2020 at 08:28
Hi Michelle,
I like the idea of the Scosche Magnetic Mounts, does the mount actually go into the CD player just like you insert a CD? The ad from JBHiFi does not really a plain how you mount the mounts. If so, will it damage the CD player?
FollowupID: 904698
Follow Up By: ExplorOz Team - Michelle - Friday, Jan 24, 2020 at 12:12
Hi Macca, not really sure what you mean? These are MAGNETIC mounts - ie. you affix the supplied magnetic mounts to both the dash/part of vehicle and the back of the device. We have 3 different ones - all the mounts are slightly different but all use the same concept of a magnet for clamping the device to the location you have chosen. The magnets are supplied with a sticky back fixture.
Michelle Martin
FollowupID: 904708
Follow Up By: Kazza055 - Friday, Jan 24, 2020 at 14:05
I think Macca might be referring to the MagicMount CD, the back of it fits into the CD slot of your radio.
I have sent them an email to find the best on for my Samsung TAB.
FollowupID: 904714
Follow Up By: Member - McLaren3030 - Friday, Jan 24, 2020 at 16:51
Hi Michelle,
Sorry for the confusion, I was referring to the CD Mount, Kazza055 has answered my question, thanks Kazza055.
FollowupID: 904727
Reply By: Michael H9 - Thursday, Jan 23, 2020 at 07:59
My android phone has a 6" inch screen and works great so I don't need two devices. The screen is quite nice, I watch movies on it at night as well. It takes 2 sims as well so I get Telstra and Optus reception which is handy in places like Oodnadatta that are Optus only cells. I want a sat sleeve for it next.
AnswerID: 629641
Reply By: Phil G - Thursday, Jan 23, 2020 at 17:55
I've used a lot of different devices, but the 8" Samsung Tab S SM-T705Y has been the best. Having had 7", 8" and 10" tablets and laptops of various sizes, the 8" is the keeper.
I've had it for about 4-5 years - it has the super amoled screen that is visible even side on with polaroid sunnies. A bit light on for storage so i have to use a micro SD to store my maps for Oziexplorer. GPS works very well. It sucks the power, but the solution for me is a Jaycar adaptor that has 2 x 2.4A (4.8A). It uses the same microUSB connection as my sat phone, Tomtom, jumpstarter and a few other things!
AnswerID: 629647
Follow Up By: Gramps - Thursday, Jan 23, 2020 at 18:02
OK Phil, you win. And I thought my dash was crowded.
FollowupID: 904687
Follow Up By: Allan B (Sunshine Coast) - Thursday, Jan 23, 2020 at 18:19
Phil, is that the cockpit of your car..... or your Cessna? lol
FollowupID: 904688
Follow Up By: Phil G - Thursday, Jan 23, 2020 at 20:35
Haha, fair comment but Not much space on the dash of a Troopy! But you sit high and none of it obstructs the view of the road. Most functional dash I've had
FollowupID: 904691
Reply By: Swaggie - Friday, Jan 24, 2020 at 03:17
Be Aware if it’s bumpy and hot these units can shut down, mate and i own similar Samsung units and have found we had the same issues out in The High Country, over all tho there a great way to go, just wait for them to kool down and reboot...
What’s the hurry out there right.
AnswerID: 629653
Follow Up By: Member - Warren H - Friday, Jan 24, 2020 at 10:19
I have had over heating issues with top dash mounted Samsung S4 and Nokia 6 phones. Black phones overheated, white S7 phone in white case was OK. Lenovo E8 floor mounted at mid-dash height out of the sun was ok, but this was May to July.
NT Pajero
FollowupID: 904705
Follow Up By: Frank P (NSW) - Friday, Jan 24, 2020 at 14:25
By happy accident I mounted my Samsung tablet where it gets enough cold air from an aircon vent to keep it cool, even if it's in the sun.
FollowupID: 904715
