CPAP [ Sleep apnea machine ]
Submitted: Wednesday, Feb 19, 2020 at 11:13
chris a
Good day Guys I will need a machine soon Will they run off 12 volt in my van and
how munch power will I need for over night Thanks
Chris
Reply By: Kazza055 - Wednesday, Feb 19, 2020 at 11:40
I went through this some years ago and I found most at that time used a 240 to 12V DC power supply although it was not alway obvious straight away.
Some of them supplied a 12V kit consisting of a simple ciggy to DC plug and charged very high prices whereas you can make a lead or by on eBay for only a few dollars.
630136
Reply By: new boy - Wednesday, Feb 19, 2020 at 11:42
I have Resmed machine with a humidifier when brought I paid for a 12 volt adaptor .What they draw I don't know but turn the humidifier off and you should have no probs
630137
Follow Up By: Member - DW Lennox Head(NSW) - Wednesday, Feb 19, 2020 at 14:10
I also have a Resmed unit with the 12 volt pack. It works beautifully..
Regards Duncan
905393
Follow Up By: Gordon B5 - Wednesday, Feb 19, 2020 at 22:51
Another Resmed Man here the adaptor isn't all that cheap but I've not had a problem. Turn off the heated hose & humidifier to reduce power use started running
mine off 2nd battery in car now have it all set up in my camper 2 x 85 ah batteries managed with a Redarc BMS never had a problem and have been away for up to 4 months at a time. I found that I didn't need humidifier so left the blanking plate in permanently. Great machine in my opinion when I first got it my wife couldn't sleep, didn't know if I was dead or alive everything was that quiet including me.
905407
Reply By: Rangiephil - Wednesday, Feb 19, 2020 at 13:48
Just check the specs.
I helped out a bloke who had one to find his battery was flat after 6 hours.
Detailed look at the specs showed 5 amp draw at 12 volts
630138
Follow Up By: mechpete - Wednesday, Feb 19, 2020 at 16:00
I have a mate who has travelled extensively with me
an his cpap machine runs straight off the battery in 4wd
never had an issue with batteries
mechpete
905395
Follow Up By: Kazza055 - Wednesday, Feb 19, 2020 at 16:44
I think you will find the humidifier will chew up a lot of power, I would turn it off and just use the air pump while on battery.
905396
Reply By: Ozhumvee - Wednesday, Feb 19, 2020 at 14:05
As has been said find a machine that can run direct on 12v without the need for expensive 12v adapters.
I have two machines one at home and one in the Oka and both run direct on 12v. One is a Phillips Respironics and one a Devilbiss Intellipap II that has a lower power draw than many others even with the humidifier running.
Steer clear of Resmed machines as they run on 24v and require an expensive power cord for 12v use as
well as a penalty for the extra power usage caused by the power supply having to step up from 12v to 24v for the machine.
My experience with the so called travel machines is that while they usually lighter with a smaller footprint they are often much noisier than a full size machine and possibly not as long lived or robust.
As I use a nasal pillow because I have a beard I find that humidifier use is necessary to avoid the air drying my nasal passages out.
We have a large lithium battery and plenty of solar so power use isn't a problem for us.
I have taken my Devilbiss machine on a touring trip sleeping in a swag and it was fine with a 12v lead running from the tour mob's catering trailer overnight.
630139
Follow Up By: eaglefree - Wednesday, Feb 19, 2020 at 17:32
X2 for the devil boss auto model. I’ve never used the humidifier but it has very low power consumption.
Simply disconnect from the 240v cord in the bedroom then reconnect to 12v cord in caravan. It’s also very quiet.
905397
Follow Up By: Member - Cuppa - Friday, Feb 28, 2020 at 20:24
x3 Have been using my Devilbiss Intellipap2 (DV64) for long term travel in our Tvan. Small power consumption. Small footprint (about the same as a 2 litre ice cream tub) Adding the humidifier does not increase the footprint. Runs direct off 12v & comes with a 240v power supply which has been useful when we have stayed in houses. It's not a travel machine, but I think it outdoes all the travel machines I've seen both in regard to cost & quietness. It's as quiet as a Resmed machine. Sometimes I use the humidifier (when in areas of very low humidity - eg, Red Centre) but it uses a different technology (Pulse Dose) than all the others. Proper humidification but with much lower power requirements. After over two years fulltime on the road I still think it is the perfect 'non-travel' travel machine. On my pressure setting range 7 to 9 I use around 20Ah per night, rising to around 26Ah per night withe humidifier on a low setting. Most RV battery systems should cope with that with ease.
905553
Reply By: Jarse - Wednesday, Feb 19, 2020 at 17:55
I have a Resmed S10, and it uses 4-5A at my settings (heated tube and humidifier) with the 12v power converter..
630140
Reply By: Gbc.. - Wednesday, Feb 19, 2020 at 21:19
I found out the hard way last sept that my old boy’s 24v unit running through the inverter will happily flatten my 3 x 120a battery setup in the camper each night.
Moral = buy the right one.
630142
Follow Up By: Ken O3 - Friday, Feb 21, 2020 at 08:54
Has to be something seriously wrong with these batteries if the machine flattens them or possibly the inverter is powering something else as
well. My Resmed S9 with humidifier running and using a 300watt inverter happily runs all night off a 120aH AGM battery when off
grid.
905428
Reply By: braincell - Thursday, Feb 20, 2020 at 10:03
Yeah , I had my brother sharing my camper trailer on a fishing trip ,. He had it going all night , I crimped his intake hose off for fun . woke up pretty quick .But ,
630144
Follow Up By: RMD - Friday, Feb 21, 2020 at 08:38
BUT what! he died anyway?
905427
Reply By: Members - Bow - Friday, Feb 21, 2020 at 08:13
Depending on why you need a CPAP a dentist might be able to supply a solution that does not require power.
630156
Follow Up By: Gordon B5 - Friday, Feb 21, 2020 at 17:11
I not sure a dentist is the correct person to see for a diagnoses. Sleep apnea can have serious results if not treated correctly. I was sent for a night in hospital by a cardiologist and he went ballistic when he viewed my result and untreated or mistreated can & does result in death. there are a lot of people advertising all sorts of remedies and I don't know if any research has been done on them but I would be careful .
Gordon
905429
Follow Up By: Jarse - Friday, Feb 21, 2020 at 18:38
A mandibular splint might work for snoring, but it ain't a total solution. If your sleep study says you need a CPAP, then it's highly likely you need one.
If you're on a compliance program for your driver's licence or similar, the splint won't cut it for hard compliance data...
905431
Follow Up By: Members - Bow - Friday, Feb 21, 2020 at 19:36
I was sent to a dentist by a specialist after having a sleep study.
A mandibular splint only works for snoring , but I found it easer to live with than a CRAP machine.
905432
Reply By: Geoff K4 - Monday, Feb 24, 2020 at 10:00
Look at ResMed Airmini. They are designed for travelling and are pocket sized. They use very little power if you buy the 12-24 volt plug in converter. Don't use a 12-240V inverter as they are known to blow the device up plus it will consume more
battery power. It runs on 24V with the converter.
Fully automatic and/or resettable for any need. Cpap or constant modes.
The ResMed site has the details.
630204
Follow Up By: Jarse - Monday, Feb 24, 2020 at 17:53
I'm about to sell one of these. Pretty much brand new with about 30 hours use, with heaps of gear, including humidifier discs.
I never really got to use it, so surplus to requirements.
905485
Follow Up By: chris a - Wednesday, Feb 26, 2020 at 10:23
THANKS EVERY ONE
905500
